Mouse pointer
    Dietmar
    Posts: 114 from 2003/2/26
    Can the MorphOS mouse pointer be changed?
  • »31.08.06 - 08:32
  • ASiegel
    Posts: 1397 from 2003/2/15
    MorphOS 1.4.5 and older versions do not include this feature, I am afraid.
  • »31.08.06 - 09:43
    Jupp3
    Posts: 1193 from 2003/2/24
    I think I heard that you can use AmigaOS mouse prefs to create custom 3 color pointer. Well, I think I already explained why I never even tried it :-)
  • »31.08.06 - 10:00
    Posts: 2217 from 2003/2/24
    You can also change it by swapping the gfx-card between Voodoo and Radeon ;)
  • »31.08.06 - 13:12
    Posts: 423 from 2005/4/9
    "You can also change it by swapping the gfx-card between Voodoo and Radeon ;)"
    what you mean?
    zx.spectrum@3.5
  • »31.08.06 - 20:32
    Schlonz
    Posts: 131 from 2004/4/16
    @saddam:
    When you use a Voodoo the mouse pointer has fewer colours than when you use a Radeon.
  • »31.08.06 - 20:45
    Korni
    Posts: 473 from 2006/2/23
    You can do it by replacing MorphOS:Prefs/env-archive/sys/Pointer.prefs to other Pointer.prefs :) This can by done by Pointer prefs from AOS3.1 :)
    P.S: Some time ago i used pointer from AmigaOS1.3 :)
  • »31.08.06 - 20:58
    thx!
    well i didnt recognize any differences when i changed my gfx card from voodoo to radeon... but good to know:)
    zx.spectrum@3.5
  • »03.09.06 - 10:43
