CATWEASEL MK IV PCI
    rigardie
    Posts: 45 from 2006/3/21
    hi this is my first post before 5 minutes i got a brand new pegasos 2 system i have brand new catweasel 4,exist any possibility to use it with linux,or better with morphos?
    thanks!!
    pegasos has any flopy controler?
  • »13.05.06 - 08:31
    Posts: 2728 from 2003/2/24
    If you want to use catweasel on MorphOS you should go for a MK3 instead. Then you can use the floppy controller for Amiga floppies, and the SID and joystick ports in C64 emulator (was it Frodo?).
    Yes, the Pegasos has a floppy controller, but it's a standard PC controller, and MorphOS does not have any support for it (and probably won't have either, since floppies are a dead medium these days) ...
  • »13.05.06 - 08:41
    Posts: 1520 from 2003/2/24
    @rigardie
    There are no drivers for CW mk4.
    @tmhgm
    CW mk3 SID chip is supported and works in Frodo. Digital joystick ports are supported on Frodo via lowlevel.library (Frodo doesnt have direct support for them).
  • »13.05.06 - 10:07
    rigardie
    ok thanks (for liux exist any working drivers?)
    thanks
  • »13.05.06 - 11:20
    SoundSquare
    Posts: 1214 from 2004/12/1
    yes there are some drivers on linux for MK4
  • »13.05.06 - 11:22
    rigardie
    ok thanks!! do you know the url for drivers?
  • »13.05.06 - 13:35
    SoundSquare
    i used google, typed "catweasel mk4 linux drivers" and found lots of links.
    Ok i'll stop being grumpy and give you at least one link : http://llg.cubic.org/cw/
    good luck
    [ Edited by SoundSquare on 2006/5/13 16:42 ]
  • »13.05.06 - 13:41
    killlbilll
    Posts: 95 from 2004/5/19
    Is there possible to read C64-floppies with PC 5.25-drive & Catweasel in MorphOS?
    [ pegasos ii / g4 | morphos1.4.4 ]
  • »13.05.06 - 15:57
