Kens Icons set
    Posts: 1930 from 2003/10/19
    Check out my latest grab! I am using the icon set called Kens Icons from OS4 depot. They work well with morphOS and look fantastic.
    https://morph.zone/modules/myalbum/photo.php?lid=887
  • »26.04.05 - 15:13
  • Targhan
    Posts: 2833 from 2003/2/8
    Very reminiscant of OS3.5+'s GlowIcons...
    :idea:Targhan
  • »26.04.05 - 16:51
    hooligan
    Posts: 1948 from 2003/2/23
    Why wouldn't they work with MorphOS.. they are normal newicons afais? :)
  • »26.04.05 - 17:40
    klesterjr
    Posts: 196 from 2005/4/1
    No -- they have a 256 color palette.
    They only work with 3.x if you have the PowerIcons patch -- so I wasn't sure if MorphOS could display them without any "patches".
    BTW -- Acill's Butterflies.
  • »27.04.05 - 02:45
    hooligan
    Hmm.. I thought Newicons had 256-color palettesupport since the beginning. The default icons with Newicons came as 32 colors though.
  • »27.04.05 - 04:01
    klesterjr
    @hooligan
    NewIcons is SUPPOSED to have 256 color icon support -- however, they don't seem to display correctly (hence the need for the PowerIcons patch) -- or maybe it's just the 3.5/3.9 implementation that needs the patch.
    As you pointed out -- the standard NewIcons "icons" used a 32 color palette -- I was pointing out that MY icons have a 256 color palette.
    [ Edited by klesterjr on 2005/4/26 18:22 ]
  • »27.04.05 - 04:31
    Snuffy
    Posts: 58 from 2005/12/4
    I'm loggedin; I'm registered, but never get to see anything. What's the problem at my end:
    A1-XE/G4/OS4 ?
    Snuffy
    Forum: MorphOS App. Compat.
    Thread: Kens Icons set
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=3495&forum=16
    This function is only avaible to Registered Users.
    Right now you are either not logged in, or not registered.
    Click Here To log on the site if you are already a Registered User
    If you are not yet a user on MorphZone: The MorphOS Portal
  • »19.01.06 - 04:08
    klesterjr
    Edit: Removed link.
    [ Edited by klesterjr on 2006/1/19 18:52 ]
  • »19.01.06 - 06:45
    winterhunter
    Posts: 204 from 2005/10/13
    Snuffy wrote:
    A1-XE/G4/OS4 ?
    Snuffy
    I'm also logged in, also a registered user, and I also get this message quite often when trying to follow links.
    Is this normal?
  • »19.01.06 - 07:25
    Posts: 65 from 2003/2/10
    Same problem here. Look the screenshot :
    http://lordfpx.free.fr/x/registration.jpg
    And with every link to the galery
    N'cha, LorD
    http://www.lordfpx.com/
  • »19.01.06 - 08:00
    koan
    Posts: 303 from 2005/11/21
    The gallery is offline at the moment.
    See https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4168&forum=14
    A new gallery is here
    https://morph.zone/modules/mg/index.php
    but seems a bit empty.
    koan
  • »19.01.06 - 08:17
    winterhunter
    @LorD:
    Maybe we are second-class denizens of the Morphzone realm? ;-)
  • »19.01.06 - 08:35
    winterhunter
    @LorD:
  • »19.01.06 - 08:36
    Snuffy
    Hi koan,
    ' A new gallery is here
    but seems a bit empty...'
    Thanks that helped. I hope a lot of files get restored eventually.
  • »20.01.06 - 02:32
