Lame PPC
    Bifford
    Posts: 283 from 2003/2/24
    Hi all,
    With MOS1.3 Lame 68k was highly unstable on my system and Lame PPC refused to work alltogether.
    While chatting in #morphos on IRC Zapek said he would make a new version that does not use PUP (as this is broken in 1.3). The new version works great on my system and encodes a standard length music file into mp3 in about one minute.
    I have uploaded the executable to the Downloads section so please everyone help yourself, and a big thanks to Zapek.
    TTFN
    Bifford
    Bifford the Youngest
  • »06.07.03 - 06:42
    Madgun68
    Posts: 60 from 2003/4/16
    Now all we need is a program that'll save the audio tracks to cd. I've tried using MakeCD a few times, but it seems pretty unstable when you're saving individual tracks to disk. (Sometimes it works 100% while other times it will randomly stop responding.)
  • »06.07.03 - 10:27
    Wishmaster
    Posts: 342 from 2003/6/29
    Did you try the CDDA command alread or Secondspin which is using the CDDA command?
    Dunno if this is working on Pegasos.
    Pegasos PPC
  • »06.07.03 - 11:42
    Robin
    Posts: 741 from 2003/2/24
    Tried cdda with ide-drives, did not work.
    Only with scsi I got it to read the data.
  • »06.07.03 - 12:50
    tokai
    Posts: 1289 from 2003/2/25
    @madgun68:
    You've propably encountered the ide lockup bug. This has nothing to do with makecd. It's a problem of the ide.device (I'll hope this will be fixed for 1.4!).
  • »06.07.03 - 16:49
    realstar
    Posts: 298 from 2003/2/24
    Try increasing the buffers on MakeCD. I was
    having a few lockup problems but they disappeared
    once I made the buffer around 50MB. Works quite
    good now, although I am really looking forward to
    a new version of BurnIt.
  • »06.07.03 - 23:34
    Spidey
    Posts: 568 from 2003/2/24
    I've bought a copy of MakeCD a few months ago and set the buffers at 4MB and everything works.
    I use a small CLI-util (forgot the name of this util) with DirOpus4 to translate MP3-files to AIFF-files and these files I burn succesfully on a cd as audio-tracks.
    And yes, I'm also waiting for the new BurnIt (because of DVD-support :-))
    Spidey
  • »07.07.03 - 09:09
    Posts: 12526 from 2003/5/22
    Since half a year ago there is http://jahjah.free.fr/morphos/lame.lha .
  • »09.07.03 - 02:19
    Henri
    Posts: 73 from 2003/5/14
    @ tokai:
    This is a bug in the ide.device?
    Good to hear, because I tested some days with
    MakeCD and the settings/tooltypes to find
    out, why the drives are 'hanging' sometimes
    (I garbaged 3 cdrs because of that).
    The bug is know to the MOS-team? Are they working on it?
    I hope it will be gone with MOS 1.4
    Regards
  • »10.07.03 - 09:14
    Henri
    @ Spidey:
    MakeCD supports MP3s directly, if the mpega.lib
    is installed (with MOS 1.3 it is).
    So, click 'New' (for a new track), then below
    'source' click as long as 'Image-file' appears and
    then select the MP3-file. So You can burn MP3->CDDA
    on the fly (mostly 12x speed with G3-600) or make
    an CD-Image first.
    Regards
  • »10.07.03 - 09:58
