CopyIcon44 & IconX . . .
    klesterjr
    Posts: 196 from 2005/4/1
    I'd like to more actively support MorphOS in future releases of 'Ken's Icons'.
    My install script uses CopyIcon44 to install the icons -- can anyone confirm whether or not this program works with MorphOS?
    I also use IconX -- does MorphOS have this (or at least a version of it)?
  • »09.06.05 - 01:45
  • HAK
    Posts: 225 from 2003/2/24
    Hi klesterjr,
    There is a native IconX in the standard MOS distribution (MOSSYS:C/ to be precise).
    Bye HAK
  • »09.06.05 - 06:03
    klesterjr
    Cool. Anyone willing to d/l CopyIcon44 from Aminet & see if it works? (or better yet -- TRY the installer  :-) )
  • »09.06.05 - 09:18
    Posts: 1520 from 2003/2/24
    CopyIcon44 needs icon.library V44 which is not supported in MorphOS.
  • »09.06.05 - 10:25
    klesterjr
    I was afraid of that.
    Are there any MorphOS alternatives?
  • »09.06.05 - 10:35
  • Visitor
  • what about copyicon for morphos?
    dont know if this is the same or somthing like this you are searching for.
    http://www.ppa.ltd.pl/software/download/CopyIcon.lha
  • »09.06.05 - 10:59
    klesterjr
    Thanks for the suggestion -- but the 'read-me' says that it is only for PNG icons (mine are 256 color GLOW icons).
  • »09.06.05 - 11:09
    Posts: 2077 from 2003/6/4
    On some setups it should work, there are some ppl who use the Workbench on MOS instead of Ambient or Scalos, they have installed the OS3.9 icon.library.
    I guess on these setups it should work.
  • »09.06.05 - 11:34
  • deb
    deb
    Posts: 76 from 2004/11/17
    this one?
    http://jahjah.free.fr/morphos/iconificator.lha
    [ Edited by deb on 2005/6/9 14:46 ]
  • »09.06.05 - 11:45
    Posts: 1932 from 2003/10/19
    I actually use that version for your icons on my machine here Ken. It works fine. The glow icon becomes just a small black square in the copyicon app but after you put the destination icon in swiches over just fine.
  • »09.06.05 - 12:59
