Mencoder usage under Devedie
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi all,
    I have to encode some videos for which I use mencoder for MorphOS 0.91 and all works very well!
    Now the only problem I have is that the video film, which is more or less 8 min. long, comes in 2 files (in this example: video_001.avi which is 1 GB and the 2nd video_002.avi which is 750 MB) and I could not find a solution to join the 2
    files before (or after) encoding them with mencoder in order to get a 8 min. final avi.
    I tried to find a program on the net to join files, like "block" from Christian Rosentreter, but it seems not to work for this application.
    If anyone has an idea how I could solve this I would very much appreciate.
    Also there are several commands like Audio CBR or Algo Quality etc. in Devedie: Encode I was not able to find docs for.
    Thanks in advance for all your help.
    Christoph
  • »20.05.05 - 17:10
    roschmyr
    Posts: 211 from 2003/2/20
    @RMS
    for joining/splitting try joinsplitter
    http://www.onyxsoft.se/files/joinsplitter.lha
    i already joined some mpeg with joinsplitter
  • »20.05.05 - 17:55
    Ingo
    Posts: 103 from 2004/3/19
    Hmmm maybe i'm stupid, but how can 1,7 GB be a 8 minute video? Huh?
    Just curios, not that i know how to fix your prob ;-)
  • »20.05.05 - 19:39
  • rms
    rms
    @ Ingo
    well this is the problem, the files come from a peecee!
    They are uncompressed digital video in avi format.
    Now the peecee does a split per 1GB (I dont know but it seems that filesystems on peecee do not support more than 1 GB per file) and that is why I have to join them.
    After encoding this 1.7 GB video, which is 720x576, using high quality setting in mencoder it's only about 230 MB!
    Regards
    Christoph
  • »21.05.05 - 03:43
