Help with FPSE and OS4 Emu
    magnetic
    Posts: 2129 from 2003/3/1
    Hi guys
    I'm running the latest OS4 Emu and I just downloaded FPSE. When I try to launch FPSE GUI it seems to mess up the system. Nothing happens and the mouse pointer gets all slow and jerky. Does anyone have this running?
    If so, Please post here how to get it running and any secrets/tips you may have :-)
    tia
    magnetic
  • »08.05.05 - 21:29
    Chain-Q
    Posts: 350 from 2003/10/12
    FPSE GUI needs ClassAct stuff IIRC, but it also doesn't work for me. Maybe a missing class, or something. However, FPSE itself, started from the command line works very well and stable.
    [.Hosting AmigaSpirit.hu.]
  • »08.05.05 - 21:53
    BatteMan
    Posts: 294 from 2003/2/24
    Use the GUI form #amigazeux : http://stefkos.amigazeux.net/FPSE_GUI.lzx
    /me uses this ;)
  • »08.05.05 - 21:59
    magnetic
    Cool
    Thanks for the help guys.
    Batteman that gui is nice and works.
    1 more question if you guys dont mind? Do I need some sort of PS1 rom or so? I have a ps1 and ps2..
    oh and
    2. Are joypads supported?
    tia
    magnetic
    [ Edited by magnetic on 2005/5/8 13:09 ]
  • »08.05.05 - 22:08
    Posts: 1087 from 2003/3/24
    1: Yes you need a BiosRom.
    2: Cos OS4 lacks Joypad/Stick support FPSE lacks it to, but you can plug an USB-Pad in you Peg and configure the Buttons as Keyboard input!
    [ Edited by ThePlayer on 2005/5/8 19:28 ]
  • »08.05.05 - 22:26
  • deb
    deb
    Posts: 76 from 2004/11/17
    @magnetic
    You have to patch the system first, write this in your user-startup
    C:PatchLoadSegOS4 >NIL:
    I think FPSE-GUI only uses MUI Classes, use snoopium to see wich you are missing.
    [ Edited by deb on 2005/5/9 5:30 ]
  • »09.05.05 - 08:20
    Posts: 1521 from 2003/2/24
    Are you sure you are using the latest os4kernel.library (V11.2)? Older version (1.6) of os4emu had broken MUI wrapper and everything calling MUI simply crash. Very likely you have an older version in MOSSYS:Libs and it doesnt belong there.
  • »09.05.05 - 20:04
    1) You need PSX Bios.
    2) I cant really remember if FPSE supported lowlevel.library or AmigaInput at all. If it supports then joypad might work - or not. Never tested that much.
    Post at AmigaWorld.net and ask? ;-)
  • »09.05.05 - 20:17
