Posts: 929 from 2003/7/13
Ah vovka, we're having trouble.
I tried 1.10 and that had the sound skipping and other problems. I tried changing the options and frame-skip and overlay and so forth and I still had problems. I added the config and prefs files you posted in this thread, no luck. Then I downloaded and installed the latest 1.1.1 from amirus.ru.org and that just crashes MOS hard, and I added the config and prefs file there too, still crashes.
I will have to dig up a previous version. I guess I have it on a CD somewhere. Does anyone know where we may download the latest Devedie before 1.x?
Update: I found some older Devedie versions on Aminet:
here.
Last update: I downloaded Devedie 0.50. This still works. It also doesn't seem to require rexxsys.lib. I'd prefer to use software that doesn't require stuff like that. A status or debug window pops up behind the video but I think this always happened with 0.50. Doesn't really bother me.
[ Edited by Velcro_SP on 2005/4/23 5:06 ]
[ Edited by Velcro_SP on 2005/4/23 6:18 ]
Pegasos2 G3, 512 megs RAM
