Posts: 2129 from 2003/3/1
Hi
Sorry for the deb troubles. Be sure to log onto freenode.org irc channel #pegasosppc for linux and pegasos help..Also join ppczone.org..
I'll try to asssist here though.
For screen res you can manually change your XF86Config-4 file to get the modes..
Your ethernet problem is probably becuase the new Deb builds default eth0 to the GigE port. Just go to /etc/interfaces/network (iirc) and change to the Via 100baseT port for eth0.. hope this helps.
magnetic
