dual boot on Peg1 ?
    judas
    Posts: 175 from 2005/1/14
    I never found this question answered completely, so I have to annoy you again. (Sorry for that :-)
    Is there a way to have an dual boot option on PEG1, just like you get with GRub or lilo-bootloaders ?
    Switching my bootfile to MorphOS is simple, but for linux, I need a notepad to get the options right ... not very nice for a quick boot change..
    bye
  • »11.02.05 - 14:25
    Robin
    Posts: 741 from 2003/2/24
    http://www.morphos-news.de/software.php?lg=en&search=boot
  • »11.02.05 - 15:14
    judas
    Unfortunetely this fails on my Peg1.
    It says something like "no such variable $boot" and stops.
    Maybe it's Peg2 only ?
    bye
  • »11.02.05 - 16:20
    Robin
    I've no clue ... I'm still MorphOS-only ...
    (Hope the Linux-DVD arrives tomorrow ;-) )
  • »11.02.05 - 16:26
    analogkid
    Posts: 720 from 2004/11/3
    the bootcreator has a "alternative" switch for Peg1. Dual boot (MOS 1.4 and Debian Linux) works fine for me.
  • »11.02.05 - 21:15
    judas
    Yep. It workX !
    I had to replace the ide:0 with /pci/ide/disk@0,0:0 .. Maybe that's Peg1.specific...
    Nevertheless thank you for directing me the right way ...
  • »12.02.05 - 14:51
    ossian1961
    Posts: 123 from 2004/7/31
    I make this bootmenu with bootcreator after I've installed Debian (sarge) on a partition on my 80Gb hd and it's ok.
    [VERSION]
    1
    [TITLE]
    Boot Menu
    [SETTINGS]
    AbortOnKey = false
    Timeout = 9
    Default = 1
    [SECTION]
    Local HD -> Morphos (Normal)
    ide:0 boot2.img ramdebug edebugflags="logkprintf"
    [SECTION]
    Local HD -> Morphos (Debug)
    ide:0 boot2.img ramdebug edebugflags="logextended logkprintf permmemtrack memtrack"
    [SECTION]
    Local HD -> Linux 2.6.8 (Normal)
    hd:4 linuz-2.6.8-powerpc root=/dev/hda5
     :-D  :-D  :-D
  • »13.04.05 - 17:08
    ossian1961
    oops.. I forget.. I've got a Peg 2.  ;-)
  • »13.04.05 - 17:11
