is ReqAttack Ambient compatible ?
    serge
    Posts: 725 from 2003/2/20
    Does it works? Well ? Middle? Crash?
    thanks?
  • »09.03.05 - 16:57
    Posts: 1521 from 2003/2/24
    It should work but I dont know if it is any use on MorphOS... and it doesnt know about MUI requesters.
  • »09.03.05 - 17:44
    Posts: 3321 from 2003/3/5
    As far as I know it should work just fine, but I fail to see the point in using it on MorphOS ;) I think the last version I released had some MOS specific changes but that was years ago...
  • »09.03.05 - 18:28
    Posts: 62 from 2004/9/8
    @Serge:
    On my peg2 with MOS 1.4.2, reqattack works fine :)
    Jacadcaps good :)  8-D  :lol:
    PegasosII G4 512Mo 80Go ATI RADEON 9200SE....
    Yeah! The best it's MorphOS :)
  • »09.03.05 - 19:31
    Posts: 408 from 2004/7/15
    2 Serge:
    Why the hell do you need to use runtime patches with an open source software? Join the project and implement animated requesters! :hammer:
    iPod, iBook, iMac,... iRobot?
  • »10.03.05 - 10:54
