Try Targh's new Beta!
  • Targhan
    Posts: 2833 from 2003/2/7
    Hi all!
    I've just finished up a beta version of an update to ib2amirc. This script allows you to post a url into an amirc window. Download via the attachment!!!!
    Using a FastLink or Context Menu, you can send a URL to an AmIRC window without having to stop, cut, and paste.
    If you have multiple AMIRC windows open, you will get a requester asking for which window you would like to send the url.
    This version requires RMH.library, AmIRC, and IBrowse.
    Thanks to CISC, Piru, JacaDcaps, and KennyR for their help on this one!
    Targhan
    [ Edited by Targhan on 2004/11/18 15:05 ]
     Attached file(s)
    :idea:Targhan
  • »18.11.04 - 19:01
    DSLCC
    Posts: 246 from 2003/5/14
    Cool! :) THANKS! Can anyone say which version of IBrowse works best on MOS?
     :-D
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »18.11.04 - 19:23
  • Targhan
    The latest version of ibrowse coarse ;-)
    note: the script will work under voyager, it just needs the file bits changed to "executable" and given %w as an arguement. I was just going to change the name and protection bits here (w/better docs) before calling it a release.
    I'm guessing with a little care it will also work under AWeb too.
    oh yeah, I'm fairly sure it will work quite well on classic amigas too.
    [ Edited by Targhan on 2004/11/18 15:51 ]
    :idea:Targhan
  • »18.11.04 - 19:51
  • Targhan
    Okay, renamed as URLtoAmIRC, and have updated the thing with a quick installer and a guide including instructions for Voyager.
    See attached file:
    todo: an icon or two.
     Attached file(s)
    :idea:Targhan
  • »19.11.04 - 20:02
    analogkid
    Posts: 716 from 2004/11/3
    great script, thank you !
  • »22.12.04 - 19:27
