ClassAction File Manager
    Posts: 236 from 2003/7/28
    Has anyone got classaction? (classaction.lha) the ReAction based file manager to work under MorphOS?
    I have installed ClassAct 3.3, and I know it is working because the AWeb Beta for MorphOS runs, but if I try to double click on the ClassAction Icon nothing happens...
    I have also tried the OS 3.9 classes, but I get the same result.
    Thanks
  • »04.11.04 - 19:27
    DJBase
    Posts: 745 from 2003/4/6
    Requires: AmigaOS 3.5 or 3.9
  • »04.11.04 - 19:45
  • Targhan
    Posts: 2833 from 2003/2/8
    You might want to dig around (maybe archive.org?), as classaction was at one time also available in MUI, BGUI, and several other gui flavors.
    :idea:Targhan
  • »04.11.04 - 20:01
    That is true, except the old versions are nothing like the newest version, which requires ReAction. I tried the OS 3.9 classes, but nothing happens after I click on the icon, and there is really nothing in Snoopdos wrong that I can see. :(
  • »04.11.04 - 20:07
    Posts: 1520 from 2003/2/24
    Uhm, I ran ClassAction under AmigaOS 3.1 ... It *should* run in MorphOS too.
  • »04.11.04 - 21:02
    thefab
    Posts: 92 from 2003/8/19
    the reaction one suxx,
    you should try the 3.6 version, it's mui, and it works under mos
  • »04.11.04 - 21:35
    ChatDEau wrote:
    If you Google it, it's the first link:
    ClassAction 3.6 (MUI & GT)
    That is true, but the current ReAction version - 4.5, is totally different (and much better) than the older 3.6 MUI version...unfortunately.
  • »05.11.04 - 13:53
    Actually the ReAction one is much newer and nicer to use, just IMHO. Unfortunately it doesn't seem to work under MOS :(
  • »05.11.04 - 13:54
