ImageFX_Lite and AutoFX - solution
    March
    Posts: 91 from 2003/7/30
    After a few days of using ImageFX_Lite I found a nasty and annoying bug in AutoFX Hook. Every time it executes any command, it opens annoying requester, saying that setting some variables failed. This is bug in AutoFX code, because it has "hard-coded" path to RXSET command (in code it is "Sys:RexxC/RXSET"). However in MOS RXSet command is in MOSSYS:C.
    Solution is really simple: Make a directory RexxC in your SYS: drive and copy MOSSYS:C/RXSET command there.
    This should be added to FAQ IMHO.
    PS. I tried to fix AutoFX binary using HEX editor, but after any modification it crases. :(
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »03.08.04 - 21:07
    cecilia
    Posts: 459 from 2003/8/30
    don't forget to check out the ImageFX mailing list.
    there's alot of useful info and brains to pick!
    if someone forgot about the mossys way that MOS is set up, don't forget, IFX was made for classical amigas first.
    but your point is well taken. altho i wouldn't call this a "bug". :-D
  • »04.08.04 - 00:18
