mysql & ixemul problem
    BigGun
    Posts: 150 from 2004/6/18
    I'm trying to get mysql (sixk port) running on MOS. It seems the MySQL version does not like the MOS ixemul.library. I tried to use 68k ixemul but somehow MOS does not like it. Most gg program like ls stoped working now.
    Can anyone tell me which library will be compatible with mysql and MOS ?
    thanks in advance
    Gunnar
  • »27.06.04 - 09:26
    GK_LKA
    Posts: 481 from 2004/3/28
    Same problem here. I need a working, and up-to-date standalone apache too...
    [ GK / LKA Team ]
  • »27.06.04 - 15:32
    tokai
    Posts: 1289 from 2003/2/25
    When i need something which is not available the i try to make a own port. :-)
    It's not as difficualt as it sounds on first. I needed subversion and i needed mkvtoolnix... i tried to port it and in the end i had working binaries who can do the job.
    It's just that you have to try it, before you can complain (and i complained and sweared a lot :-P )
    regards,
    tokai
  • »27.06.04 - 15:43
    brotheris
    Posts: 142 from 2003/2/24
    Now someone needs to make tokai need Apache and MySQL :-P
    Home sweet home is Pegasos User Group Lithuania
  • »27.06.04 - 20:55
    GK_LKA
    @brotheris:
    Yes! :D
    @tokai:
    Ok, but I don't know anything about C, Amiga programming, and Linux programming... How to start? (Ok, I have already the MOS SDK, but then?)
    PS: Don't you want to compile a new, working version of Apache with 2.x GD and standalone support? :) That's all I want :)
    [ GK / LKA Team ]
  • »27.06.04 - 23:57
