FinalWriter97
    micken
    Posts: 42 from 2004/6/7
    Hi all
    Does anyone know how to get the cursor in a different
    colour than white. You cant see the damn thing on
    the white document.
    /micken
    MorphOS hangaround :)
  • »07.06.04 - 06:53
    Posts: 1520 from 2003/2/24
    FW97 never worked correctly on RTG and I doubt you could make it usable on MorphOS...
  • »07.06.04 - 07:59
  • Targhan
    Posts: 2833 from 2003/2/8
    @micken
    Your best bet for FW97 is to go to the View menu, select "Preferences." Then, in the "Display" tab, find the WB Document Color box. Select "Use Pen 0." this will change the document color to grey, and make FW97 a bit more usable.
    :idea:Targhan
  • »07.06.04 - 08:17
    gunne
    Posts: 441 from 2003/2/25
    Hi
    Select - Open New Screen - Same as Workbench
    Works excellent here.
    Gunne
    Best wishes, Gunne
  • »07.06.04 - 08:20
    micken
  • »07.06.04 - 15:19
