MUI classes
    Posts: 1932 from 2003/10/19
    I downloaded a few MUI classes that are PPC native, maybe even mos native from the custom classes page. They end in .mcc.elf ect. Do these go in the sys/classes/mui folder with the rest? I put them in there to test so I can use YAM. The toolbar.mcc.elf was required and seems to work fine where I put it. I just wanted to make sure I did it correctly.
  • »24.05.04 - 15:58
    Robin
    Posts: 741 from 2003/2/24
    You are in charge of your system :-D
    So if it works what can be wrong ? ;-)
    I've renamed them and removed the .elf
    for a unified look of the classes.
    But in general all 3rd-party classes
    schould be stored to sys:classes/mui
  • »24.05.04 - 16:11
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    sys:classes/mui/ is correct.
    Since later versions, the .elf is optional. I think the loader always checks for .elf first. I have been keeping this on for the 3rd party stuff I add, just so I know which is PPC and which isn't from a quick glance at the filenames!
    Steve
  • »24.05.04 - 16:11
