calibrating joypad
    klapdeur
    Posts: 132 from 2003/6/28
    hi guys can you help me i have a microsoft sidewinder joypad its
    working on peg but i cant get it calibrated with snes etc. snes plays
    not that great from keyboard.
  • »10.04.04 - 15:13
    Posts: 916 from 2004/1/24
    Do you mean a usb joypad? I'm also having trouble getting it to work with snes9x -> poseidon identifies it correctly as an eight-butten 2-axis joypad, but in ambient in behaves like a mouse. I tried raw keymapping, but that didn't work too wel (got some response in the game, but after one button press it stopped).
  • »10.04.04 - 16:16
    Posts: 2531 from 2003/2/24
    @Stevo
    That sounds like you have missed the last Poseidon-update.
    Get it here.
  • »10.04.04 - 16:23
    klapdeur
    well thats the problem i have the latest version of usb stack for mos
    installed and got the same probs with it to calibrate
  • »10.04.04 - 19:33
    @Kronos
    Thanx for the tip. I have installed the update, but I am still faced with the same problem. I can map the raw keys to the buttons (is there a way to use the stick btw?) but after pressing a button ingame it keeps the mapped key pressed -> it won't release the key after you pressed a button.
    Suggestions/ideas/step-by-step explanations anyone ;-) ?
  • »11.04.04 - 08:12
    Bladerunner
    Posts: 418 from 2004/2/19
    Stevo:
    Well you really should read the ####ing manual :-D (BTW if you did`t find it, it is located in Help: )
    It seems as if you have totally messed up your joystick config, because you shouldn`t have rawkeys atached on your buttons, but enabled the lowlevel.library instead.
    I made this yesterday with my brandnew Logitech Gamepad (A Playstation look-a-like pad) and it works like a charm.
    Here is what i have set:
    Hat switch (for the stick/pad)
    Type Trigger Params
    Digital joystick NaN Release hatswitch port 1
    Digital joystick Always Assign hatswitch (port1)
    Button 1
    has trigger > any and Parameter assign red (fire)
    oh btw, don`t forget to set Port 1 in the "General" tab to "Merge with USB"
    well so you can set every button to your needs, and the usb lowlevel.lib replacement has at least support for all 7 Buttons (instead of the MOS`lowlevel.library for the gameport) of the original lowlevel.lib
    For Mame e.g. (and if there are enough Buttons left) you might want to assign a keystring combination o and k so you can start your games without touching your keyboard again ;-)
  • »11.04.04 - 08:27
    @Bladerunner
    Oops......ehm, okay, my mistake :-D -> should first have read the manual before crying out for help...but now I have, and I'm afraid that it doesn't help me a lot :-(
    I copied the settings you wrote down, but (apart from the buttons) it won't work too well. I tried "Digital joystick NaN Release hatswitch port 1" for the x-axis and "Digital joystick Always Assign hatswitch (port1)" for the y-axis, I tried it the other way around and I tried both lines for each axis. At 50% of the times there is a respons, but for a quarter/half of the direction pad, and even than incorrect. This is for snes9x -> couldn't get any respons from MAME :-(
    I hope that I'm an absolute idiot, and that you (or someone else) could offer some more advise?
  • »11.04.04 - 10:07
  • Targhan
    Posts: 2833 from 2003/2/7
    Figure it would be good to know for anyone configuring their USB joybad for use with Snes9x to know what keys do what: The Snes9x Tutorial for another OS has a picture of the keyboard layout for the keyboard :-)
    :idea:Targhan
  • »24.05.04 - 02:25
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    In fact, you don't need to press o and k. Pressing left and right (or the contrary) simulates the ok sequence.
  • »24.05.04 - 07:13
