Make CD
    Pepillo
    Posts: 16 from 2004/4/4
    Why do not register MakeCD?
    My Morphos say:do not open the registerscript and no record my serial
    number.
    Help and sorry for english.
  • »17.05.04 - 17:21
    Robin
    Posts: 741 from 2003/2/24
    Not sure if I understand it right.
    But MakeCD stores it's preferences to
    it's icon. And if I remember correct
    you should use the original icon and not
    a PNG one ...
    But I'm not sure ...
  • »17.05.04 - 17:46
    Posts: 918 from 2004/1/24
    Correct: just use the original icon and you'll be allright :)
  • »17.05.04 - 17:52
    Bladerunner
    Posts: 418 from 2004/2/19
    You can nevertheless change the Icon later, I use a png Icon for make CD and it works very well here.
  • »17.05.04 - 17:56
    Pepillo
    No,the original icons is Working,not a PNG.
    X(, say dont execute the script >>registerscript<<!
  • »17.05.04 - 17:57
    Posts: 1521 from 2003/2/24
    Registration information is stored in the file comment. If you copy MakeCD installation from your old Amiga HD use CLONE option for copy command.
  • »17.05.04 - 18:06
    Dr_Fred
    Posts: 1 from 2004/5/17
    I don't know exactly where MakeCD stores it' Registerinformations but you can not copy MakeCD. Copy the comment is useless, it won't work... Even if you "defragment" your HD (using reorg) the Registerinformation is gone...
    Just install MakeCD from it's archive and type your register code...
    Now everything should be fine  :-)
  • »19.05.04 - 05:27
    Pepillo
    Hello;
    I have plugin my HD of Amiga in the Pegasos.
    I execute the MakeCD program from the HD Amiga and is 100%
    functional.
    If execute the MAkeCD fromthe HD of Pegasos no fuction(not open
    registerscript)
    I have clone all with Directory OPus but no fuction.
    How to clone with the command line,please?
  • »19.05.04 - 17:54
    You need triton.library as well.
  • »19.05.04 - 22:04
    Just download the latest version of MakeCD from aminet, install it from scratch and than use your old registration number; that should do it.
  • »20.05.04 - 07:06
    Jupp3
    Posts: 1193 from 2003/2/24
    umm, is the newest beta there?
    I'd get it from http://makecd.core.de just to be sure, it's the newest one...
    btw, I just changed MakeCD icon with CopyIcon, didn't even lose registration information, and it seems to work...
  • »20.05.04 - 08:24
    Spidey
    Posts: 568 from 2003/2/24
    Hi Jupp3,
    It didn't work for me. I had to install MakeCD all over again from scratch on my Peg.
    After that I was able to fill in my reg code.
    Bye,
    Spidey
  • »20.05.04 - 19:47
    Aaron
    Posts: 127 from 2003/6/14
    Is it still possible to register MakeCD?
    --Aaron
    --Aaron Diezman
  • »20.05.04 - 20:02
    Wishmaster
    Posts: 342 from 2003/6/29
    Ask at Vesalia.
    Pegasos PPC
  • »20.05.04 - 22:13
