MACos X and hard files and drives.
    serge
    Posts: 725 from 2003/2/20
    Is it possible to use hard files in place of partitions?
    Is there any limitation for partitions ? Like obliged to be in first 4 GO? I'm having trouble with MACOS-X installation
  • »29.04.04 - 14:41
    Donar
    Posts: 142 from 2003/12/27
    My OSX Partition (Physikal) is after about the first 50 Gigabytes of space (MOS DATA LINUX and so on. I had trouble during install when my "virtual" OSX drive was about 8 Gig big. after i resized the first "virtual" partition in the Physikal area to about 7.5 Gig then making another bigger "virtual" partition i had no problems. A "virtual" Partition here is something that is inside the space of a physikal partition.
    Hope you are not too confused with my explanation.
  • »29.04.04 - 17:01
    serge
    how can you create virtual partitions?
    I only way I found to use a partition is declaring it on molrc.macos.
    Can you create partitions on it with mac tools?
  • »30.04.04 - 06:18
    Posts: 261 from 2003/3/13
    I use a 2 GB OSX hardfile, and it works
    very good.
    How to create a hardfile, check:
    Http://www.attention-software.com/
    In the news section you will see a
    MOL guide, there are instructions
    how to create a hardfile.
  • »30.04.04 - 15:24
