Posts: 1193 from 2003/2/24
the buttons work perfectly but the directional cross give strange signal (right is left for example).
That should be easy one to fix... Start MAME, when game is running hit "TAB" to get to the menu.
Then select change controls (for this game or every game)
Then locate "Player 1 left" (or however it's written in prefs) and press enter on it, then press joypad direction you want to use to move left. Repeat for other directions.
easy, eh?
Of course you can do the same with buttons aswell...
