Mounting devices
    wlamee
    Posts: 59 from 2004/2/18
    Hey all,
    When mounting a device which may or may not be present (like an external SCSI device being switched on or off) by using a mountlist in DEVS:DOSDrivers, it doesn't seem to work very well:
    - If the device isn't there, I get a 'please insert device MYDEV:' requester during startup, which of course interrupts booting and I'll have to cancel the requester before it continues.
    - If the device is there, it does not seem to mount at all.
    - After booting, double clicking the mountlist in DEVS:DOSDrivers (with default tool 'mount' and tooltype 'ACTIVATE=1') slows everything down for a few seconds and has no effect.
    Only when typing 'mount MYDEV:' in a shell it seems to work. Anybody also found this problem (on a Peg2 1GHz with MOS 1.4.2) and maybe has a solution for it, or does MOS 1.5 maybe fix it?
    Wouter Lamee
    mailto:wouter@wouterlamee.nl
    http://www.wouterlamee.nl
  • »07.04.04 - 06:16
    magnetic
    Posts: 2129 from 2003/3/1
    I hope you get help on this.. i'm not clear how to help..
    magnetic
  • »07.04.04 - 22:10
