MorphOS 1.4.5 ISO for Peg1/Peg2
    Cego
    Posts: 738 from 2006/5/27
    Ignoring Rave3D for R300 is the same as dropping Warp3D for R300. Its not a side effect. It is exactly what was intended in the first place.
    Lets just agree to disagree here ;)
  • »17.02.20 - 16:08
    Posts: 12542 from 2003/5/22
    Just that the reasons for dropping Rave3D for R300 had nothing to do with Goa/Warp3D.
    No, the reasons for dropping Rave3D are no secret. They were disclosed by the MorphOS team at the time and they are not about Goa/Warp3D.
    I have no reason to distrust the MorphOS team regarding the reasons they presented :-)
  • »17.02.20 - 16:27
    Cego
    Ok, that’s new information. What was the reason to drop it then?
  • »17.02.20 - 16:35
    Divinity
    Posts: 518 from 2009/9/8
    "SML=SafeMemLists/S - Use old MorphOS 1.x-style memory system with extra safety checks. This could be useful for debugging some buggy applications for example. SML is much slower than the new MorphOS 2 memory system however."
    https://www.morphos-team.net/installation
    ok thanks
    zukow wrote:
    Regarding 1.4.5 and 2.x/3.x, for checking the compatibility one can disable new memory system in boot args.
    tested with "boot ide:0 boot.img rd sml" , nothing is changed ... (graphic of the game is perfect, CD audio in is perfect, AHI not working)
    Any other idea how to fix the AHI problem ?
    [ Edited by Divinity 17.02.2020 - 20:57 ]
  • »17.02.20 - 19:56
    Chain-Q
    Posts: 350 from 2003/10/12
    TinyGL is no longer running on top of Rave3D indeed, therefore a Rave3D driver for the R300-R500 series was never developed. And of course the Warp3D wrapper (Goa) still runs on top of Rave3D drivers, and only those. It's also the reason why in recent MorphOS you can't run TinyGL applications on R100 Radeons and Voodoo cards, for those, no direct TGL driver exist, only a Rave3D one. The only cards where both drivers exist - for now - are R200 Radeons.
    However, it would be possible to make a Rave3D "backend" driver, which uses TinyGL or its drivers to render, which would allow Warp3D and its applications to run on R300 and above (as new drivers for even newer Radeons might get developed. The only reason this don't exist, is that it really wasn't a priority for key people working on 3D stuff, and with that, lack of time, and expertise from others. Not to mention the aforementioned key people might be busy with other MorphOS components as well.
    [.Hosting AmigaSpirit.hu.]
  • »18.02.20 - 10:45
