Posts: 207 from 2003/2/20
dkaram schrieb:
Anyway, I selected the regional settings etc but in the hdconfig there was no listing for my internal sata disk.Does it need anything special to show the internal sata of the powermac g5 or is it a problem of my g5 machine?
[ Edited by dkaram 15.06.2014 - 09:53 ]
does the SATA hd a jumper 1,5Gb/s, i had the same problem with a newer SataII hd
and solved the problem with this jumper.
