thermal sbar
    amiga4001
    Posts: 454 from 2006/11/16
    What does this mui class do?
    I get not graphical response when I turn the module on?
    I would expect that it should display temperature off cpu gpu etc?
    I am on a powerbook model 5,4.
    On my other powerbook 5,8 it does show the temperature.
    Is the 5,4 model not compatible with the class maybe?
    [ Edited by amiga4001 25.07.2014 - 03:34 ]
  • »24.07.14 - 19:12
    Posts: 1370 from 2010/1/6
    Normaly yes! But I'm not sure whether your PB model is supported......
  • »25.07.14 - 06:04
