MorphOS Library updates
    tolkien
    Posts: 576 from 2013/5/29
    Good article about Game controllers.
    I have tried a XBOX360 joypad with the MS usb cable and i can't use it. Trident shows a "?Running" state.
    Don't know is I need a Pc USB adapter or what.
    Will try a PS4 one meanwhile.
  • »25.10.15 - 08:53
    diezi7
    Posts: 167 from 2005/7/25
    Hi Mate, on a previous thread it was said the
    only supported version was the one with usb wireless
    adapter for PC.
    Regards !
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »25.10.15 - 09:06
    tolkien
    Thanks friend. I'm using a ps4 one while I get a pc adapter.
    [ Editado por tolkien 25.10.2015 - 13:10 ]
  • »25.10.15 - 10:09
  • ASiegel
    Posts: 1396 from 2003/2/15
    Great stuff! Thanks.
  • »13.01.16 - 15:54
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Thanks! Especially for the beginners guide, as I am still a noob with MorphOS.
  • »13.01.16 - 17:39
    Posts: 2217 from 2003/2/24
    As a related thing, I made a script (MorphOS and "Linux" versions) to fetch and display shell command descriptions from the MorphOS Library:
    http://aminet.net/package/util/batch/Chelp
    Screenshot: Chelp.png
    [ Edited by jPV 30.01.2016 - 10:45 ]
  • »30.01.16 - 06:12
    igracki
    Posts: 469 from 2003/2/24
    Good idea jPV!
    I started to copy all the descriptions of your shell commands to Locale:Help/.
    My script would then first look if there is a localized description of the command, if not the english version is taken.
  • »30.01.16 - 11:05
    Drako^lM
    Posts: 144 from 2005/8/10
    jPV wrote:
    Something about mounting network drives.
    Good work
    Hardware :
    Power Mac G5 2.3 Ghz & MorphOS 3.18 & OSX 10.5
    Mini G4 1.5 Ghz & MorphOS 3.18
    BlaBla Team Member -> http://blabla.ppa.pl
    AmiParty Team Member -> http://www.chal.pl/
  • »07.02.16 - 06:11
    Posts: 1932 from 2003/10/19
    I just read through the network drive article. Its fantastic! Great work on that one. We need an easier way to discover and contribute to these.
  • »07.02.16 - 14:45
    Thanks!
    What do you mean by that?
  • »07.02.16 - 14:59
    Drako^lM
    @jPV
    Great article ... I plan make this same in future about lua ;)
    Also Krashan make a very good work with port and integration with OS
    Hardware :
  • »13.02.16 - 18:18
    Intuition
    Posts: 1116 from 2013/5/24
    Excellent!
    Who needs Hollywood? ;)
  • »13.02.16 - 18:44
    Great work, very much appreciated. That took a lot of your time, so even if not everyone here expresses their thanks, know that your time and work are appreciated by more people than post in this thread.
  • »13.02.16 - 21:24
    Posts: 2090 from 2003/6/4
    Intuition schrieb:
    Excellent!
    Me.
    But i need Lua, too.
    It's similar in many things and Hollywood is based on it, but Hollywood is noz Lua and Lua is not Hollywood. They differ and they both have their advantages and disadvantages. It's pretty nice to have them both.
  • »13.02.16 - 22:01
    Intuition
    Zylesea wrote:
    Intuition schrieb:
    Excellent!
    Me.
    I know, I own Hollywood and think it's great. Was only being silly. :)
  • »13.02.16 - 23:40
    tolkien
    Damn! Thanks so much. That is a great work.
  • »02.09.18 - 10:03
    ernsteiswuerfel
    Many thanks, especially for the OpenFirmware part! From time to time I have to fiddle around with that and needed to search for the relevant information bits every time, 'cause I keep forgetting this OF stuff again and again... So good to know the relevant information is now at one place! :-)
    Besides, on the Filesystem page you got two little errors I think. For SFS and FFS max. filesize should read "2 TiB" instead of "2 bytes" I guess.
  • »02.09.18 - 11:19
    Posts: 12537 from 2003/5/22
    It's neither. Correct is 2 GiB minus 2 bytes and 4 GiB minus 2 bytes, and that's what's written on the page :-)
  • »02.09.18 - 13:10
    Nope, it's 2 bytes under 2 or 4 GiB (2 or 4 GiB minus 2 bytes) :)
  • »02.09.18 - 13:12
    ernsteiswuerfel
    Mkaye... Would not have thought that!
  • »02.09.18 - 13:28
