Something wrong
    Posts: 1087 from 2003/3/24
    The "latest Discussions" block on the frontpage and the top 25 under "Hot & New" is mixed up with old threads. Maybe Targhan should take a look at this.
  • »29.11.08 - 15:44
  • ASiegel
    Posts: 1397 from 2003/2/15
    Everything appears to be fine as far as I can tell.
  • »29.11.08 - 16:26
    Golem
    Posts: 766 from 2003/2/28
    @ASiegel
    If you look at the last post column you should notice a few out of place posts.
  • »30.11.08 - 07:20
  • ASiegel
    @ Golem
    I can confirm this for the frontpage but the top 25 contains no entries that appear to be out of place. If you take a look at the "last post" dates of all listed threads, they seem to be perfectly in order. On the frontpage, on the other hand, some dates appear to be different than what is displayed in the top 25 list.
    [ Edited by ASiegel on 2008/11/30 13:22 ]
  • »30.11.08 - 09:08
  • Targhan
    Posts: 2833 from 2003/2/7
    Unfortunately, "LastPosts" module development was abandoned when the site engine went through it's last major overhaul. Thus, to be able to have a separate module, I had rewritten some of the code. I fear that I may be pulling off the wrong date out of the database for that module.
    [edit]
    There is, however, a chance that the forums/topics need to be synchronized. I will do this right now to see if that will help fix the problem. If not, then I will have to double check all the date calls within the two modules to make sure that the right "date" is being asked for.
    [ Edited by Targhan on 2008/12/1 12:44 ]
    :idea:Targhan
  • »01.12.08 - 16:41
