Search is broken
    koan
    Posts: 303 from 2005/11/21
    Is there any chance of getting this fixed ?
    Thanks
  • »20.11.07 - 21:46
    Golem
    Posts: 766 from 2003/2/28
    Works for me, maybe you could provide us with just a little bit more information?
  • »20.11.07 - 23:03
    dIGIMAN
    Posts: 273 from 2005/11/7
    It never worked for me either.
    I found out that i works when i search in a specific forum (The Bar, etc)
  • »21.11.07 - 08:00
    koan
    @Golem
    If I scroll down to the bottom of any forum page, there is a search box on a tab. I enter a simple search term that should return many hits, e.g. "amiga" or "DVD" and I get the result ~ "No pages match, please broaden your search".
    I tried typing keywords into the search dialogue underneath the null result and still no matches.
  • »21.11.07 - 22:47
    Golem
    Ok, you're refering to forum search, site search still works.
  • »21.11.07 - 22:56
    weiseb
    Posts: 214 from 2003/3/29
    to add to what Golem wrote:
    When you use https://morph.zone/search.php
    you also get Forum posts.
  • »22.11.07 - 01:04
    koan
    Thanks.
    I see the link now. I don't normally scroll down the index page so far!
  • »22.11.07 - 04:44
