Bounties page
    pampers
    Posts: 1061 from 2009/2/26
    Hi
    I think bounties page (http://bounties.morph.zone/) needs a proper fix and clean up. There are links (css, links on the top) with the old domain name.
    Also I think content should be cleaned up. Some open bounties will probably never happen, maybe this money could be moved somewhere else?
    MorphOS 3.x
  • »20.02.17 - 16:05
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Moving a browser bounty (Sputnik) to another browser bounty (Odyssey) would make sense. ^^
  • »21.02.17 - 07:28
    pampers
    Papiosaur wrote:
    Move Sputnik bounty to Odyssey 1.25 bounty ;
    Is there Oddysey bounty? I see no description, terms, expected sum or developer assigned.
    MorphOS 3.x
  • »21.02.17 - 07:35
    connor
    Posts: 650 from 2007/7/29
    Papiosaur wrote:
    This is some quick ideas :
    This sounds useful because it is unlikely that someone will work on Sputnik in the future. OWB is not perfect but it is better than Sputnik. But the question is if this sum will help Fab to improve OWB the way most people expect it. What I read is that he lacks time and not money in the first place. Before assigning it to him a new goal has to be defined.
    Give Spreadsheet Application bounty to Carsten Siegner ;
    This does not sound useful to me as this program is very buggy. It often locks up or is unstable, and usage is often quite illogical and long-winded. If it ever becomes stable and tested in some years, then it might make sense to offer him this bouty. But up to now it is not really usable.
  • »21.02.17 - 09:37
    Posts: 1353 from 2004/2/8
    Well, they say time is money... And they're quite right on that.
    Maybe if we set a goal that Calimero should be stable and support basic operations flawlessly... Then the bounty would make some sense.
  • »21.02.17 - 10:17
    deka
    Posts: 136 from 2013/2/12
    I think, the acceptance criteria should be extended to have a stable and logical working editor.
    This could push Carsten to make a bit better work...
  • »21.02.17 - 11:24
    connor
    Who is “they”? Fab and his wife? Or just the general saying? Does this money buy him a nanny for his daughter to have more time coding for MOS? Does he even WANT to exchange money for having time with his daughter? He should be asked first, I think.
    I don’t believe that actually but I would be happy to convinced one day. So far only one single tiny program from Carsten was stable enough for me to be used. All others were too buggy to be used. Which is a pity for all the work that went inside. And all the other programs were much less complex than Calimero.
  • »21.02.17 - 15:27
    No, i didn't mean Fab, that's just a figure of speech.
    Personally I think he deserves a lot more for all those earlier versions of OWB he gave us for free. That said - it would be nice if he could propose some bounty himself.
  • »21.02.17 - 15:57
    NewSense
    Posts: 1578 from 2012/11/9
    koszer wrote: Maybe if we set a goal that Calimero should be stable and support basic operations flawlessly... Then the bounty would make some sense.
    connor wrote: I don’t believe that actually but I would be happy to convinced one day. So far only one single tiny program from Carsten was stable enough for me to be used. All others were too buggy to be used. Which is a pity for all the work that went inside. And all the other programs were much less complex than Calimero.
    I am of the same opinion about Carsten, and I thought it was only me. :-o
    I would need to see a program that everyone agrees is stable, and useable - in realistic terms, as any kind of hybrid text or graphics handling is not going to do any of us MorphOS users, or any potential user, any good seeing something that doesn't do what you'd expect of it.
    Spreedy doesn't work properly and that was Carsten's initial 'stab' at a spreadsheet program.
    Calimero doesn't even handle text properly, never mind all the trouble explaining to him that his tables in the spreadsheet part of Calimero didn't work properly. Carsten seem to do things his own way, rather than follow more standard methods of doing his programming, from what I can make out. He needs to standardise his program(s) so that it meets any users standard expectations of what a program that is titled wordprocessor or spreadsheet or DTP, and it should be stable, and not require a 'stack' of 2,000,000. :-o
    I don't think at this point in time offering money to Carsten is the way to go. If others feel the way, as those above, and also as I do, then I could not justify or feel like offering some 'Bounty' money to Carsten just now. I wish I could but at the moment it would just probably be like throwing money away.
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »21.02.17 - 22:12
  • ASiegel
    Posts: 1396 from 2003/2/15
    Thanks for pointing this out. It's been cleaned up.
  • »24.02.17 - 08:11
    Posts: 12521 from 2003/5/22
    You may want to update the footer ("MorphZone.org") also :-)
  • »24.02.17 - 08:45
