Expanded icon set
  • k8o
    k8o
    Posts: 57 from 2013/5/29
    Hi all,
    I really like the "PatIcons" set designed by Patrick "Patbest" Jung.
    But I found a need for new icons to suite my needs for both drives and folders.
    And as I currently use the PatIcon set I decided to begin expanding it further using its style as the base theme. You can see an early preview here:
    There's still alot more icons to make but i'll upload it when i'm finished, any ideas or requests are welcome, thanks.
  • »27.06.13 - 07:28
    Yasu
    Posts: 1724 from 2012/3/22
    I'm actually doing the same (but with someone elses icons so it's not perfect).
    Here's a preview from me:
    My MorphOS blog
  • »27.06.13 - 11:25
  • k8o
    k8o
    Nice Yasu! That's the "Gant" set if i'm not mistaken?
  • »27.06.13 - 13:57
    SteveE617
    Posts: 80 from 2013/1/26
    k8o
    nice icon set, I can't wait to try them out. Very well done!!
    Steve E, BSOE, MIS
    PowerMac G5 | Dual 2.0 Ghz | 2 GB | 32GB CF | 9800XT
    AmigaOne x5000 | 8 GB | 1TB | Radeon 7770HD
  • »27.06.13 - 15:12
    Intuition
    Posts: 1110 from 2013/5/24
    k8o wrote:
    Hi all,
    Very nice indeed. :)
    Call me old-fashioned but I use Ken's Icons on my 68k machines, my MorphOS machines and my KDE/Linux boxes too.
    http://www.five-star.com/icons.htm
  • »27.06.13 - 16:01
    connor
    Posts: 570 from 2007/7/29
    I am a big fan of double state icons, especially those from Mason: http://www.masonicons.de . He painted a huge amount of them not only for OS3 and OS4 but also for MOS and AROS usable. Ken added a lot of good icons, too. It's a pity that Ambient comes only with one state icons and has problems to read some of the double state ones and just displays wrong colours and garbage graphics.
  • »27.06.13 - 19:08
  • k8o
    k8o
    those masonicons are very nice, especially nice are the tools and applications icons, some of the device icons are nice too. i don't like the drawer and drive icons though, but that's just personal preference.
    his work is very inspiring though and he is very talented, i also wonder if morphos will get 2-state icons some time, i don't see it as a high priority though.
  • »27.06.13 - 19:38
    Intuition
    MorphOS already supports two-state icons, Ken's icons are two state and work fine on my MOS3.2 machines.
  • »27.06.13 - 20:20
  • k8o
    k8o
    Oh I was totally unaware of that! Awesomeness indeed! I will have to experiment with 2-state icons as well now :)
  • »27.06.13 - 20:34
    Yasu
    k8o:
    Yep :) It's not complete regarding to MorphOS, but I've covered every def_icon with the existing sets. If someone else wants them that is.
    My MorphOS blog
  • »27.06.13 - 21:36
  • k8o
    k8o
    Hi all,
    So since i'm really busy with uni work for another month or so I thought i'd release the pack I have now, as i'm sure some of you might find these icons useful...
    I made (re-made) a lot of Game icons as the ones we have or default ones are really poor imo, and i like to keep some consistencey..
    The main reason for this pack was for me to have new drive icons for all the samba shares ive been connecting, and they look and work great. Theyre all in here too.. I will make a much bigger update after all my work is done.
    For now i've uploaded them to aminet and morphosfiles, probably take a couple days to appear there, but you can get them directly here for now:
    ftp://ftp.untergrund.net/users/keito/morphos/k8o_IconPack-1.lha
    here is a small preview:
    [ Edited by k8o 10.08.2013 - 19:05 ]
  • »10.08.13 - 19:05
    Intuition
    Very nice, I use mostly Ken's icons but i've just used a couple of your drive icons as they look nicer. :)
  • »10.08.13 - 20:30
  • k8o
    k8o
    Intuition,
    Glad you like them Intuition, it's nice to know some of them are being used so thanks for the reply :)
  • »10.08.13 - 20:53
    stefkos
    Posts: 96 from 2004/2/4
    I will use some of them too.
    Good work and waiting for more:)
    k8o wrote:
    Intuition,
  • »11.08.13 - 14:28
  • k8o
    k8o
    @Papiosaur - of course you can use them, feel free, glad u like them :)
  • »11.08.13 - 16:24
    Tcheko
    Posts: 510 from 2003/2/25
    @k8o
    Can you add a default folder icon without any decoration over in the icon set?
    Thx. :)
  • »11.08.13 - 16:36
  • k8o
    k8o
    Tcheko,
    @k8o
    Sure here it is:
    folder.info
    Note that this folder icon is originaly from the "PatIcons" set designed by Patrick "Patbest" Jung.
  • »11.08.13 - 17:46
  • k8o
    k8o
    Papiosaur,
    Can you add too default disk icon for set-1 & set-2 without any decoration over in the icon set ?
    Sure, sorry for my slow response, been doing homework :)
    You can download plain drive icons for each set here:
    disk1.info
    disk2.info
  • »14.08.13 - 18:56
  • k8o
    k8o
    Hi everyone, I dug up this old(ish) thread as I did not see any point starting a new one as my post is directly relevant. I'll cut to the chase now, I have worked on a few more icons themed on my original set, so you could call it an expansion pack if you like :)
    I'll post a preview here and also a link to the download, but it should be apeearing on morphfiles and aminet shorty. Next time I will move onto application icons and maybe some devices too. Best wishes, Keito.
    Download: k8o Icon Pack 3
    Preview: cm2zyVD.png
    [ Edited by k8o 20.05.2015 - 19:57 ]
  • »20.05.15 - 20:55
    Toto
    Posts: 268 from 2003/4/20
    Wow, I did convert that ancient Gnome icon theme for my Pegasos 2 and A4000 ten years ago. I wouldn't touch it with a ten feet pole nowadays.
    Damn, that's old skool ;P
    [ Edited by Toto 20.05.2015 - 22:47 ]
  • »20.05.15 - 22:19
  • k8o
    k8o
    Oh i see you were quoting 2 different ppl, confused me for a minute, well thatnks for your feedback.
    Thank you.
    Keito.
    [ Edited by k8o 20.05.2015 - 22:01 ]
  • »20.05.15 - 23:00
