Markdown (.md) datatype for Multiview
    Posts: 645 from 2004/4/15
    Ok, I have the same problem on Mos.
    I need to do some debugging, because it works on Linux/MacOs and it is valgrind free.
    So it might be some problem with the SDK/Compiler.
    [ Edited by eliot 31.01.2025 - 11:16 ]
  • »31.01.25 - 10:15
    Posts: 3256 from 2003/3/5
    Doubt it. Is that a libnix or ixemul binary? For libnix, you set the stack size like:
    unsigned long __stack = (2 * 1024 * 1024);
  • »31.01.25 - 13:20
    I will have a try!
  • »31.01.25 - 14:13
    Ok, it's now working:
    md2html.lha
    If it is usable for you I will also upload it to morpohos-storage.
  • »31.01.25 - 14:55
    Papiosaur
    Posts: 2483 from 2003/4/10
    Thanks for the new exe. Just tested but unfortunally there are problems in the conversion with MD tested (https://github.com/samuilivanov/cpp-cdogs-sdl/blob/master/README.md)
    But there is a big problem here, if a MD file is not writed correctly, there is "bugs" during conversion...
    Is there a complete MD file to test with all possible correct syntaxes to see if the HTML conversion is correct?
  • »31.01.25 - 15:11
    Sorry, I did not had any time to check the README.md you pointed to.
    But I added a Makefile for MorphOS native builds to the repository.
    You can now compile it directly on MorphOS and have a look into the code if you like.
    [ Edited by eliot 01.02.2025 - 13:46 ]
  • »01.02.25 - 12:46
    Posts: 2522 from 2003/2/24
    Papiosaur wrote:
    A strange thing, if i compile without -noixemul (via cmake) all work fine, i obtain the lib and the exe and the exe work.
    Well guess what "-noixemul" means no IX (POSIX/UNIX) emulation which results in the linker complaining about those POSIX functions used but not provided.
    Now most of these have native Amiga/MorphOS counterparts which can be used instead, but since you didn't provide the actual linker error we can't even guess of which those would be.
  • »01.02.25 - 16:58
    https://github.com/samuilivanov/cpp-cdogs-sdl/blob/6bcfaf4cc7b4a138cf33fb9792150576a2be5e2c/README.md
    works here with maddy.
  • »01.02.25 - 18:35
    cmark.lha with -noixemul
  • »01.02.25 - 18:51
    Sorry, I did not use the Makefile.
    But you can build it on your own with cmake:
    git clone https://github.com/commonmark/cmark.git
    cd cmark
    makedir build
    cd build
    cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_C_FLAGS=-noixemul ../
    cmake --build . --target cmark_exe --config Release
    src/cmark --version
    cmark 0.31.1 - CommonMark converter
    (C) 2014-2016 John MacFarlane
    That's all you need to do.
    [ Edited by eliot 02.02.2025 - 07:07 ]
  • »02.02.25 - 05:58
  • MDW
    MDW
    Posts: 490 from 2003/7/25
    Papiosaur wrote:
    @Andre:
    Work perfect! thanks a lot for your help.
    I have uploaded it on the storage:
    https://www.morphos-storage.net/?id=2316980
    Great! Now we can try using the tool to join an editor with MultiView (or WebBrowser) to show an HTML preview on demand. Maybe someone will use ARexx to implement it. It could work.
    Thank you, Papiosaur and Andre, for the tool!
    [ Edited by MDW 07.02.2025 - 14:47 ]
  • »07.02.25 - 11:33
    Papiosaur
    Open FlowStudio, create a file with this code and save it to sys:prefs/Ambient/Filtypes/text/x-md
    and you could read a conversion of your MD file in HTML format on Wayfarer.
    AMTD
    1
    Type text/markdown
    Name Markdown document
    Match
    PatternHint #?.(md|MD)
    Name #?.(md|MD)
    End
    Action
    Name Read Markdown file
    Event DoubleClick
    Command AMIGADOS cmark %sf >RAM:T/file.html
    Command AMIGADOS openurl file:///RAM:T/file.html
    Flag cd source
    End
    End
    I'm not a specialist of Mimetype, maybe it could be improved.
  • »07.02.25 - 13:39
  • MDW
    MDW
    It works! Now I have the motivation to learn and get used to MarkDown syntax. :)
  • »07.02.25 - 15:12
    Markdown uses relative links to other files.
    If create it in a different dir, those links wont work!
  • »07.02.25 - 16:19
    Papiosaur
    Yes, i saw a Markdown file could have some links to others MD file present in the same root like the README.md from cmark archive with a "benchmarks" link. In this case, just doubleclick to benchmarks.md present in the same path (in Ambient window) to open it in Wayfarer at the place of README.md.
    It's not a perfect solution, but we can easiest surf on internet links too present in the MD files.
    After it there is other sort of link (to a text file for example), the user can copy the html file from RAM:T/file.html to the original path, normally all links should work correctly. Depend of the MD files converted.
  • »07.02.25 - 16:35
    An pictures an other stuff? Same problem!
  • »07.02.25 - 16:55
    https://github.com/eliot-exdev/exdev-gfx/blob/master/README.md
  • »07.02.25 - 17:43
    Yes, as said. If you create it elsewhere, they cannot be found.
  • »08.02.25 - 03:46
