VdeoClipper on MorphOS ?
    Papiosaur
    Posts: 2614 from 2003/4/10
    Hello all,
    is it possible MorpOS Team contact Kevin Taddeucci, the author of VideoClipper, to ask him it will be possible to have the source to port it on MorphOS ? maybe buy him the source.
    http://www.os4depot.net/index.php?function=showfile&file=video/edit/videoclipper.lha
    I think it will be a must have on MorphOS.
    [ Edité par Papiosaur 09.03.2013 - 11:14 ]
  • »09.03.13 - 05:30
    hooligan
    Posts: 1948 from 2003/2/23
    How is it a "must-have". For example I have no use what so ever for it... and I think I'm not alone.
    Useful tool it may be, but far from must have :)
  • »09.03.13 - 15:15
    _bigdan_
    Posts: 70 from 2009/1/7
    Hum... just a GUI for mencoder or more useful ?
    Arnaud
  • »09.03.13 - 16:00
    Jambalah
    Posts: 820 from 2008/3/30
    I guess it would be nice to have it anyway. I became mad to try option every time in command-line format, figure when you are using something like this:
    mencoder -oac lavc -ovc lavc -of mpeg -mpegopts format=dvd:tsaf -vf scale=720:576,harddup -srate 48000 -af lavcresample=48000 -lavcopts vcodec=mpeg2video:vrc_buf_size=1835:vrc_maxrate=9800:vbitrate=5000:keyint=15:trell:mbd=2:precmp=2:subcmp=2:cmp=2:dia=-10:predia=-10:cbp:mv0:vqmin=1:lmin=1:dc=10:vstrict=0:acodec=ac3:abitrate=192:aspect=16/9 -ofps 25 -o Outputvideo .mpg inputvideo.wmv
    in one line and you make an error...  :-)
    By the way, I would like first an upgrade of FFMpeg so tu use filters, ogg-vob and more.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »09.03.13 - 16:20
    Papiosaur
    @_bigdan_:
    A simple GUI is cool too :-D
    This is 3 screenshots of VideoClipper:
    http://www.os4depot.net/filedata/snapshot/7675_1_snap.jpg
    http://www.os4depot.net/filedata/snapshot/7675_2_snap.jpg
    http://www.os4depot.net/filedata/snapshot/7675_3_snap.jpg
  • »09.03.13 - 17:07
    Posts: 2578 from 2003/2/24
    Well this looks like it's using ReTarded-GUI (formerly known as ClassAct), so a proper port should be about as easy as porting somthing similar useing GTK or QT  :-P
  • »09.03.13 - 17:14
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
  • »10.03.13 - 02:42
    Jambalah
    Mencoder is really sophisticated and has a good variety of filters. I will try to compare with ffmpeg though I guess they aren't all the same.
    And I tried to encode video to theora-ogg without any success: ffmpeg doesn't have relative libs (libvorbis and libtheora) and mencoder seems to have only the vorbis codec inside:
    http://www.mplayerhq.hu/DOCS/HTML/it/menc-feat-enc-libavcodec.html#menc-feat-enc-libavcodec-video-codecs
    Encoding with mencoder gives better results in my opinion.
    Well... if you should find those couple of minutes one day.... :)
    Pegasos II 1 ghz
  • »10.03.13 - 16:40
  • rms
    rms
    Posts: 606 from 2004/11/27
    Jambalah,
    great to see that someone else needs the ogg-theora encoding becaus I would also and I didn't have any success neither.
    Fab,
    Updating ffmpeg is a couple minutes job. But most of these new ffmpeg features are already available in mencoder, anyway.
    Well if this would be possible it would be great!
    @ all
    it would be really nice to have a GUI for "small" video editing's/encodings than like Jambalah I also must every time try the command-line options before I get a wanted result.
    Regards
    Christoph
  • »11.03.13 - 03:11
    _bigdan_
  • »11.03.13 - 04:36
  • rms
    rms
  • »12.03.13 - 03:10
    Posts: 2094 from 2003/6/4
    I may try to put somthing together with Hollywood+MUI Royale. I think a basic GUI should be easy doable.
  • »12.03.13 - 07:56
