Posts: 12566 from 2003/5/22
> Piru’s reaction
...is completely reasonable. Someone else's reaction is not.
> some AI-made software, [...] with some AI-added hacks on top
I don't think Piru's warning has much, if anything, to do with that.
> it’s not even based on the stable MorphOS version
> but, if I remember correctly, on the old 68k version
Yes, absolutely. I see no reason why it should be based on the MorphOS version, especially considering that Piru writes it is based on ixemul v48.1 from 26 years ago. Can current
MorphOS ixemul v50.31 even be compiled for OS3/m68k and run there without significant changes?
> then he already knows it’s going to blow up sooner or later.
Only if installed on MorphOS by some fool ;-)
> Same story with MUI5. MorphOS has a mature, stable version. The
> OS4/OS3 version is incompatible in places and not exactly rock solid.
I don't get your point here. Did anyone really attempt to run the OS3/m68k version of MUI5 on MorphOS? I've never read of such thing. Does MUI5 for OS3/OS4 even have a higher revision number than the MorphOS version?
If you refer to running the OS3/OS4 version of MUI5 on OS3/OS4, then this is a very different story than the one Piru posted here, which is about (not) trying to run an (incompatible) OS3/m68k build on MorphOS.
