Posts: 2520 from 2003/4/10
This is the list of bugs found:
FYI, each bug found and not listed entitles you to a €5 discount on registration (See readme file for more informations)
PS: Bugs found must be send by mail please
Bugs found by Sprocki: (
fixed in 0.101)
1. New Document keeps page count from previous document — creating a new document after a multi-page one still shows the old page count.
2. Recent Documents menu contains empty entries — blank lines in the submenu after opening only one file.
3. Find: Enter on second match deletes the found text — first hit works, next Enter deletes the selection instead of jumping to next occurrence.
4. Find direction switch requires double keypress — after Cmd+B (backward), first Cmd+G (forward) is ignored.
5. Replace closes the search bar without replacing — clicking Replace does nothing and closes the bar, whether replacement text is set or not.6. Font list breaks after DejaVu Sans — selecting any font after DejaVu Sans in the list applies DejaVu Sans instead of the chosen font. Font index mismatch.
7. Bullet list dot size inconsistent — alternates between small and large dots on consecutive lines with mixed font sizes.
8. Numbered list with large font overlaps previous line — number "2." at 72px paints into the line above; text on line 2 reverts to size 12.
9. Strikethrough don't work via menu
10. Undo/Redo don't work via hotkeys
11. Print option via menu show nothing
12. Search cannot find table entries
13. Hyperlink insertion duplicating selected text14. Search only finds text inside tables if the table is already active (editing mode), or if the search term also exists in the normal text after the table. Otherwise, table content is
skipped.
Bug found by Thomas Igracki:
1. Help key show a rectangle
Bug found by skateman:
1. Add a link to text, remove the picture located below
