SDK Explorer
    Papiosaur
    Posts: 2402 from 2003/4/10
    Hello,
    i have realized a new GUI allowing you to explore the Docs from SDK.
    This is a new beta:
    https://www.morphos-storage.net/upload/test/SDK-Explorer_beta2.lha
    Install it in root of the SDK and launch it.
    TODO:
    - Some problems must be fixed (bold text in MUI Docs and problems with others files)
    - Add search function
    - Add path request for Linux users (for cross-compilation) and add MorphOS path (SDK:) to install SDK-Explorer where you want
    - add path request to add extras docs
    - add prefs file for paths
    I could add possibility to explore sources code from SDK too.
    Don't hesitate to do suggestions ;-)
    If you want to support me, you are welcome ;-)
  • »25.05.25 - 16:49
    Tom01
    Posts: 185 from 2009/9/20
    Nice app, looks good.
  • »29.05.25 - 11:07
