Raylib 5.6dev on MorphOS
    tolkien
    Posts: 541 from 2013/5/29
    A nice library. I use it in windows for a few things. I tried to port version 4 to Morphos but cpu was always to 100%.
    Fantastic news! Thanks.
  • »26.03.25 - 21:18
    Papiosaur
    Posts: 2356 from 2003/4/10
    @tolkien: yes, i think too.
    Yes, the examples code was not optimised and the CPU up to 100% on MorphOS.
    BeWorld gave me the Raylib command to active the VSYNC option and reduce the CPU usage.
    I have added stack and the VSYNC activation to all examples.
    Now, it's usable.
    Seems there is some problems with actual TinyGL with some examples. I think i will wait before a public release.
    Seem sound work correctly.
    For the moment, only tested on G5.
    Contact me if you want to test on your hardware.
  • »27.03.25 - 07:23
    tolkien
    Would be nice to try It.
  • »27.03.25 - 09:42
    beworld
    Posts: 649 from 2010/2/10
    I rework with Papio:
    You can find Fork and MorphOS support here :
    https://github.com/BeWorld2018/raylib/tree/morphos
    By defaut, i use OPENGL11 and SDL3, but you can use SDL2 with it.
    OPENGL21... seen not a good option for now (some function not implemented into tinygl)
    To use Raylib in production, you need next TinyGL release.
    For just for debug/test for now...
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »30.03.25 - 12:30
