New version of CMake?
    Papiosaur
    Posts: 2540 from 2003/4/10
    Hello,
    i would like to ask if it will be possible to have a new version of CMake on MorphOS?
    3.9.6 is obsolete for many projects unfortunaly (even if i change the minimal version in the script)
    Maybe a new version arrives with SDK 3.20?
    Thanks for your answer
  • »20.02.25 - 15:12
    Posts: 646 from 2004/4/15
    Yes, that would be great.
    But you can also cross compile.
    In this caseypu can use a newer make version of your host.
  • »20.02.25 - 16:40
