Posts: 2613 from 2003/4/10
Kronos a écrit :
At least for Ambient "reset to default" should be the same as "delete prefs file" as the default values are in the source as fallback codes.
You say if i delete all this files:
sys:prefs/Ambient/Advanced.conf
sys:prefs/Ambient/Ambient.prefs
sys:prefs/Env-Archive/MUI/Global.pref
sys:prefs/Env-Archive/sys/font.conf
sys:prefs/Env-Archive/MUI/AMBIENT.prefs
The default prefs file will appears after a reset?
Is there others prefs files for MorphOS/Ambient/MUI/etc. please?
