A tool to convert pictures
    Papiosaur
    Posts: 2621 from 2003/4/10
    Hello,
    i would like to propose a new tool to convert many pictures in others format and/or resolutions in one operation.
    Example : many pictures in jpg format converted in png format in 320x256 (just an example)
    Is there a tool for that on MorphOS?
  • »15.05.24 - 10:15
    Posts: 1099 from 2004/9/23
    That would be ShowCase (ShowGirls). It has multiple functions for that.
  • »15.05.24 - 10:32
    Cool_amigaN
    Posts: 777 from 2011/11/30
    RNO Effects also has batch coverter :)
  • »15.05.24 - 10:59
    Trekman
    Posts: 50 from 2020/11/10
    Image2PDF .... ;-)
  • »15.05.24 - 11:23
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    ImageMagick - hundreds of options, thousands of combination... but a basic conversion doesn't require a comlicate syntax. Available for many platforms so detailed documentation is available. MorphOS version is on MorphOS Storage.
    [ Edited by MDW 15.05.2024 - 15:44 ]
  • »15.05.24 - 11:44
    Posts: 2220 from 2003/2/24
    +1 :)
    You can even apply any of the provided effects in the batch conversion process, in any order you want. Everything in a simple GUI :)
  • »15.05.24 - 12:24
    And TBH, if you just want to resize images to another resolution, I think ShowCase uses Lanczos filter for that in the batch conversion, and you hardly can get better results with anything else. ShowCase also has good sharpening and color manipulation options.
    But RNOEffects is designed to use ALL program features in batch conversion, so it's much more versatile when you want to do more image processing for images, and it has better output format selection. For example, you could resize images, reduce colors on them, pixelate them, add a logo, and then remap them to a selected palette and save as IFF, etc.. all in one go. Or save images as icons, PDF, or video.
    [ Edited by jPV 15.05.2024 - 19:45 ]
  • »15.05.24 - 14:41
