someone to port iperf2
    Tom01
    Posts: 187 from 2009/9/20
    Does somebody feel like porting iperf2 to MorphOS?
    I want to measure the ethernet transmisson speed to the Fritzbox, which has an iperf2 server included.
    https://sourceforge.net/projects/iperf2/
    iperf2 consists of a client and a server to measure the tcp and udp speed.
    [ Edited by Tom01 23.10.2023 - 01:41 ]
  • »22.10.23 - 18:56
    Tom01
    nobody?
    Where is Polluks, when you need him?
    [ Edited by Tom01 27.10.2023 - 20:04 ]
  • »27.10.23 - 15:56
    Posts: 847 from 2007/10/23
    Well, what about iperf3? :-)
  • »28.10.23 - 21:16
    Tom01
    The Fritzbox has an iperf2 server included, which is incompatible to iperf3.
    Ideal would be a port of both, iperf2 and iperf3.
  • »29.10.23 - 10:43
    Alexco
    Posts: 36 from 2015/5/16
    You could use AmiSpeedTest (http://aminet.net/comm/net/AmiSpeedTest.lha) and then connect to the Fritz Box with
    AmiSpeedTest HOST=IP_OF_FRITZ_BOX PORT=4711 TTCP
    That worked for me on classic Amigas.
  • »31.10.23 - 06:06
    Indeed http://www.amispeedtest.com
    [ Editiert durch polluks 31.10.2023 - 11:06 ]
  • »31.10.23 - 09:06
    Tom01
    That works.
  • »31.10.23 - 12:19
