Problem with two vertical MUI lister
    Papiosaur
    Posts: 2434 from 2003/4/10
    Hello,
    i start a new project with Hollywood but i have a problem :-)
    If i create a GUI with two horizontal lister, all is OK.
    If i create a GUI with two vertical lister, the first lister (on the left) is not selectable.
    This is a very alpha of the GUI:
    Diapo-Creator.exe
    Maybe not supported by MUI?
    Thanks for your help!
    [ Edité par Papiosaur 21.07.2023 - 09:04 ]
  • »18.07.23 - 13:12
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    Listers look like they have 2x MUIA_CycleChain or MUIM_Window_SetCycleChain. The first one doesn't get highlighted as it should with the TAB key, but after another press it doesn't jump to the second one. Buttons and string are ok.
  • »19.07.23 - 22:03
    Posts: 2180 from 2003/2/24
    The left side listview actually gets activated when you click on it, but it just doesn't highlight the borders to indicate it.
    You can test this by dragging few files on it, and then click on the left listview and use the arrow keys to select different files. It seems to be only a visual issue for me, but it doesn't affect to the actual functionality.
    I also reproduced that two listviews in a vertical group don't have this issue, it's visible only when the listviews are in a horizontal group. Sounds like a MUI bug IMHO.
  • »20.07.23 - 04:21
  • ghh
    ghh
    The error occurs when both listers have MUIA_List_Title. If the Title is only on the left then it "works" but if the MUIA_List_Title is on the right it does not work properly.
  • »20.07.23 - 20:07
  • ghh
    ghh
    It works by putting HSpace(num) between two vertical listers.
    But it shouldn't be like this:(
  • »20.07.23 - 21:26
    Posts: 3228 from 2003/3/5
    I recommend using a Balance object between two lists.
  • »20.07.23 - 22:08
    NewSense
    Posts: 1545 from 2012/11/9
    Papiosaur wrote: I start a new project with Hollywood but i have a problem :-) . . . This is a very alpha of the GUI: Diapo-Creator-mos
    That link (which I have removed from my comment) when clicked on causes my MOS system memory on my iMac to drain away to virtually nothing, and causes Wayfarer to be unable to do anything else, and Wayfarer cannot be detached from the system even by using Task Manager's "Break" options, the system CPU is stuck at virtually 100% :-o, so it seems that your Hollywood project really is currently not fit to download via that link. In fact I'd remove it for everyone's sake until you have a more well behaved version for others to have access to.
    I won't be going anyway near that link in the near future. :-(
  • »21.07.23 - 00:02
    @NewSense
    Wayfarer likely tries to display it as html.
  • »21.07.23 - 00:33
    Papiosaur
    @NewSense: sorry for that, i have renamed the "exe" and modified the link. Seems ok now on Wayfarer and OWB. I think it was not recognized as an executable and would like to "read" it.
    @Jacadcaps: thanks a lot for the advice, it work fine now! :-)
  • »21.07.23 - 05:13
