VBCC linking issue
    Minuous
    Posts: 166 from 2010/2/12
    Hello all, I have installed VBCC on Windows and am using it to cross-compile OS4 and MorphOS versions of my programs. It works fine for producing OS4 binaries, but at the linking stage for MOS binaries it gives lots of "Reference to undefined symbol NewList" and similar errors. Is the MOS VBCC target not configured to use amiga.lib by default?
  • »21.08.22 - 12:50
    Piru
    Posts: 622 from 2003/2/24
    I'm sure it's also possible to get VBCC working, but I have no clue how that could be done. The best MorphOS cross-compiling results come by using GCC and the "official" SDK .deb from from bigfoot.
    If you really want to use Windows you can do the following:
    1. Install Windows Subsystem for Linux from: https://aka.ms/wslinstall
    2. Install Debian from Windows app store: https://www.microsoft.com/store/apps/9MSVKQC78PK6
    3. Install wget to the fresh Debian: sudo apt-get update && sudo apt-get install wget
    4. Download the SDK .deb provided by bigfoot and apt-get install it as described
  • »21.08.22 - 18:25
    Minuous
    It's Windows 8.1 so that suggestion won't work.
  • »22.08.22 - 02:31
    Posts: 847 from 2007/10/23
    I cannot see any reference to amiga.lib for +morphos
    -ld=vlink -belf32morphos -Cvbccelf -P__amigappc__ -P__abox__ -nostdlib $VBCC/targets/ppc-morphos/lib/startup.o %s %s -L$VBCC/targets/ppc-morphos/lib -lvc -o %s
    -l2=vlink -belf32morphos -Cvbccelf -P__amigappc__ -P__abox__ -nostdlib %s %s -L$VBCC/targets/ppc-morphos/lib -o %s
    -ldv=vlink -belf32morphos -Cvbccelf -t -P__amigappc__ -P__abox__ -nostdlib $VBCC/targets/ppc-morphos/lib/startup.o %s %s -L$VBCC/targets/ppc-morphos/lib -lvc -o %s
    -l2v=vlink -belf32morphos -Cvbccelf -t -P__amigappc__ -P__abox__ -nostdlib %s %s -L$VBCC/targets/ppc-morphos/lib -o %s
    for example
  • »22.08.22 - 07:22
    Samurai_Crow
    Posts: 198 from 2009/12/10
    No. ABox is the name of MorphOS' link library bindings. Amiga.lib is only for versions of AmigaOS. MorphOS has no access to the trademark "Amiga" name including the link library.
  • »27.08.22 - 19:52
    Nice story, but it's not true for VBCC:
    > search vbcc:targets/ppc-morphos/lib/ newlist quiet
    System Backup:vbcc/targets/ppc-morphos/lib/libGLs.a
    System Backup:vbcc/targets/ppc-morphos/lib/libGL.a
    System Backup:vbcc/targets/ppc-morphos/lib/libamigas.a
    System Backup:vbcc/targets/ppc-morphos/lib/libamiga.a
    [ Editiert durch polluks 31.08.2022 - 08:30 ]
  • »30.08.22 - 16:59
    Posts: 611 from 2003/4/11
    Nice story, but it's not true:
    What is still true, though, is that MorphOS SDK indeed uses libabox.a as well as libaboxstubs.a which is obviously a API compatible version replicating functions used in the original amiga.lib
    What vbcc does is not within our scope and the vbcc author supplying the link libs can basically name his libs whatever he likes to do ..
  • »30.08.22 - 20:12
