Is Anti-Grain Geometry available?
    walkero
    Posts: 104 from 2006/3/1
    Hello everyone.
    I am interested to port an editor app to morphos, which requires anti-grain geometry library (https://sourceforge.net/projects/agg/).
    Is this available for MorphOS anywhere? Unfortunately I couldn't find anything about it.
    [ Edited by walkero 26.12.2021 - 21:18 ]
  • »26.12.21 - 18:12
    Tcheko
    Posts: 544 from 2003/2/25
    We have some vgraphics.library that implements vector to raster from SVG markup. Is that of any help?
  • »26.12.21 - 19:22
    walkero
    @Tcheko
    Thank you for your reply. I am afraid it doesn't help because that would mean I should change the way the application is developed, and do that on every update. I wonder if anyone ported it for any other project, but never released it to the public.
    If there is no version, I found in Aminet an Aros port, and I might work with that to port the library to MorphOS (https://aminet.net/package/dev/lib/agg.src-aros). I guess that version would be pretty close to what a MorphOS one should be, right?
    Any recommendations by anyone?
  • »26.12.21 - 21:27
    Posts: 903 from 2003/3/4
    I'd recommend you look at porting a different editor app that doesn't require AGG. AGG is old and has been surpassed, and its main author sadly passed away in 2013.
  • »03.01.22 - 11:38
    Posts: 2578 from 2003/2/24
    Herewogoagain....
    SteamDraw has been AGG for >15 years so it does work.
    Whenever I hear someone talking bout a port I just see someone who hasn't done even the most basic homework. AGG will compile out of the box. Well not 100% you need to create Makefile.in for MorphOS (AFAIR I just renamed the Linux one) and adapt a few include path.
    Don't wander into examples area thinking you have to port the GUI toolkit found there, most can just run on the SDL backend (which is something I never really to investigated).
    -> get the library to build (if really needed I could send you a copy of mine)
    --> get your app to find all the includes and link to the lib
    ---> fix whatever other dependancies remain
  • »03.01.22 - 12:03
    Posts: 12559 from 2003/5/22
    There are people continuing the development. v2.8.14 has just been released some days ago (a year ago forked from now two-year-old SVN revision r134/v2.7, which had some minor updates later).
  • »03.01.22 - 12:16
    walkero
    Thank you guys for your replies.
    Meanwhile, I tried to compile it myself but I didn't complete it. And today I saw that another member of this community sent me a compiled version, who I thank so much for doing so.
    Take care.
  • »03.01.22 - 21:52
