compiling C source on MorphOS
    Lastic
    Posts: 22 from 2021/6/7
    Good afternoon
    Avid user of PowerPC Macs and recently after acquiring my childhood missed-dream an Amiga 500 I got accustomed to the Amiga OS and decided to install MorphOS 3.15 onto my iBook G4 14".
    I've installed the SDK, installed PowerSDL, installed SDL2 2.0.14 and I wanted to compile a newer atari800 emulator from source on MorphOS (https://github.com/atari800/atari800).
    How can I tell the configure script where the SDL libraries are , I tried with --with-sdl-prefix but to no avail , configure doesn't seem to detect any SDL presence.
    I'm guessing there is a whole different approach I need to take ?
  • »08.06.21 - 11:48
    tolkien
    Posts: 577 from 2013/5/29
    You can use -Idirpathsdlincludes in your GCC comand.
  • »08.06.21 - 14:23
    Posts: 841 from 2007/10/23
    The path is not enough better use
    sdl-config --cflags
  • »08.06.21 - 16:25
    Posts: 110 from 2020/12/24
    My raw recipe nowadays is:
    For compiling every object that uses SDL:
    -I/gg/usr/local/include/SDL2
    And at linking time:
    -L/gg/usr/local/lib -lSDL2
    Most likely you would need to add (95% of times) -noixemul everywhere.
    Yep, sdl-config can also work but in crosscompile enviroments maybe you get some headaches.
  • »08.06.21 - 16:29
    Lastic
    sdl-config --cflags
    Where can I find sdl-config ?
    To all others who replied thanks a lot for the info , will give it a try.
  • »08.06.21 - 18:31
    beworld
    Posts: 670 from 2010/2/10
    hi
    gg:usr/local/bin ?
    On atari 800 you need use only PowerSDL, not SDL2.
    My MOS ports
  • »09.06.21 - 03:35
    Lastic
    Ok first mistake, I installed the USER libraries of PowerSDL not the SDK.
    Hence I couldn't find sdl-config, that has been fixed now.
    However when running configure --with-video=sdl --with-sound=sdl it does find sdl-config
    but cannot run an test since it cannot find the SDL libraries and also it doesn't detect the SDL version .
    I've set CFLAGS="=I/usr/local/include/SDL" and LDFLAGS="-L/usr/local/lib" also tried changing it to the full path SYS:Development/gg/user/local/include/SDL but no luck.
  • »09.06.21 - 09:21
    Probably a simple hello-sdl test is the way to check if all is correct on the SDK side.
  • »10.06.21 - 04:57
    Lastic
    I combined the following info
    https://www.amigaimpact.org/forums/topic/installation-de-sdl-sdk-sous-morphos/
    https://www.badprog.com/c-sdl-simple-directmedia-layer-hello-world
    and that seems to work so still trying to figure out why the configure script of atari800 cannot find SDL altough I'm setting the CFLAGS,LDFLAGS.
  • »12.06.21 - 08:48
