Any resources on how to implement Reggae classes?
    Posts: 6 from 2018/8/29
    Hey everyone,
    I'm trying to write a Reggae class for MOD files. Other than the autodocs, I haven't found any information on how to write a Reggae class (everything in the library seems directed to someone consuming classes, not writing them).
    Do you guys know if there are any sample source code around? Something simple, like the sample libraries included in the SDK would be ideal. If not, any tips would be greatly appreciated :-)
    Thanks!
  • »07.09.18 - 17:20
    Jeckel
    Posts: 133 from 2007/3/11
    +1 on that one! There is a couple of classes I'd like to write. :)
  • »07.09.18 - 19:01
    zukow
    Posts: 658 from 2005/2/9
    I'll contact with Krashan and ask which his classes can be released as examples. I'll also release one of my classes (probably sunraster decoder/demuxer, crop filter, and maybe some en coder muxer). Which type of classes (except mod) do You want to implement?
    [ Edited by zukow 07.09.2018 - 23:21 ]
  • »07.09.18 - 19:21
    Jeckel
    Would be great!
    On my side I'd like to create at least an audio decoder and some image decoders (and eventually encoders).
  • »07.09.18 - 19:32
    Thank you so much zukow. You're awesome :-)
    I'm mostly interested in audio classes -- after the MOD one, if things go well I'd move to similar formats (e.g. MED or AHX).
    Thanks!
  • »07.09.18 - 19:57
    Posts: 845 from 2007/10/23
    At least we have deep_demuxer and deep_decoder.
  • »08.09.18 - 21:22
    Krashan
    Posts: 1107 from 2003/6/11
    You can just ask here. However I admit that some simple audio decoder/demuxer source code would be a good start. However MOD player will be a special case, as it will not stream data from the source while playing. Instead a demuxer should load the whole module from source into memory and then render some PCM audio (I guess simply INT16, which is 16-bit signed PCM) to its output. Then audiopcm.decoder will be connected automatically by Reggae, which, in most cases, will detect identity audio transformation (INT16 -> INT16) and will just forward pull requests.
    For Reggae you will need pull-driven replayer, I mean it has to be able to deliver audio frames in arbitrary sized blocks, and timing should be based solely on frame counter and requested sampling rate.
  • »12.09.18 - 17:16
    You're gonna regret saying that, believe me ;-)
    Thanks a lot for the info. I'll try to move forward with a simpler class then, and ask here in the forums if I find any problems.
    Thanks!
  • »12.09.18 - 17:50
    zukow
    Taaadaaam:
    https://expirebox.com/files/475600153264a4f7a8f2e833bf3b3656.lha
    I included my deep.demuxer deep.decoder and Krashan's digibooster3.demuxer.
    https://github.com/widelec-BB/libvstring is also required
    If you have any questions or want to your work added to official MorphOS iso as contribution please contact me (or Krashan in audio related things)
    Please also don't use own parameters/ metadata idents, just official ones.
  • »15.09.18 - 20:15
    Jeckel
    Many thanks, it will help a lot! :)
  • »15.09.18 - 20:58
    Thanks x 1000!
    This really makes things a lot easier :-)
  • »16.09.18 - 07:59
