git clone from Github fails
    asrael22
    Posts: 445 from 2014/6/11
    Hi.
    I wanted to clone a repo from Github.
    When calling "git clone https://github..."
    I'm just seeing:
    Cloning into 'Foo'...
    die() should not be called in child
    And that's it.
    Some git metadata seems to be getting downloaded but no sources at all.
    Something I'm missing?
    Manfred
  • »20.05.18 - 07:08
    Posts: 3278 from 2003/3/5
    It is a know issue. Will be addressed in the new SDK.
  • »20.05.18 - 08:42
    Posts: 839 from 2007/10/23
    Me too, do you have a hot fix please?
  • »30.07.18 - 10:02
    Unfortunately there'll be no SDK updates before November/December this year. You can use the original build from widelec though.
    [ Edited by jacadcaps 30.07.2018 - 08:09 ]
  • »30.07.18 - 10:09
    Thank you, it works.
    Because of
    Cloning into 'cc65'...
    fatal: unable to access 'https://github.com/cc65/cc65.git/': SSL certificate problem: unable to get local issuer certificate
    you also need
    setenv HOME .
    git config --global http.sslVerify false
  • »30.07.18 - 10:24
