return value by system (schell) command in C .
    Posts: 23 from 2018/4/20
    I can,t find how I do . in C programming
    Example .
    char time
    time = system (date , 0);
    *I will take the date like I type in shell "date" = Dinsdag 26-jun-2018 11.23.56
    also command diskfree
    Example .
    int free
    free = system (diskfree work: nopostfix , 0);
    * Can somebody give a easy example to do that .
  • »26.06.18 - 11:48
    BSzili
    Posts: 570 from 2012/6/8
    What you are looking for is not the return value, but the output of the command. The easiest way is to redirect it into a file in T: and read it for your program.
  • »26.06.18 - 12:24
    Correct I will use the output of cli command .
    I can read a file , no problem , if i can put the output in a file , then i must have the output ?
  • »26.06.18 - 13:37
    Tcheko
    Posts: 544 from 2003/2/25
    You should consider reading the SDK documentation. Also, there is a still valid book about all those AmigaDOS things: The Amiga Guru Book from Ralph Babel which worth to be owned just for the chapter starting quotes.
  • »27.06.18 - 04:21
    Posts: 845 from 2007/10/23
    By the way it's not a good style to depend on external commands for simple tasks if you also have a dedicated API.
    An ARexx script should of course use diskfree.
  • »27.06.18 - 11:34
