GitHub & TLS 1.2
    Posts: 845 from 2007/10/23
    FYI
    Support for TLS 1.1 is discontinued
    SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
    So you have to update your OpenSSL (1.0.1+)...
  • »04.04.18 - 17:17
    Intuition
    Posts: 1116 from 2013/5/24
    polluks wrote:
    FYI
    Github doesn't work on MorphOS for me even with the new port of git that was released recently.
    Certificate errors. Even on 3.10.
    edit: Widelec has posted a work around in the news thread for git.
    [ Edited by Intuition 04.04.2018 - 23:05 ]
  • »04.04.18 - 20:01
    thx!
    I was using the svn bridge which was broken.
  • »04.04.18 - 22:10
    CISC
    Posts: 619 from 2005/8/27
    I guess it's worth mentioning that I've added a port of GIT to our SDK, based on Widelec's work, it's using the latest openssl and curl and works perfectly with f.ex. github.
    I've also made a change to libpth so that it uses the binary's ixstack value as default for the threads stack sizes instead of 64k so that the pthread_attr workaround is no longer needed (makes it so much easier to port and test stuff using pthreads), the binaries just need a decent (or in GIT's case; insane (64MB)) ixstack value set.
    It should all be part of the upcoming 3.12 SDK release (with jaca's blessing).
    - CISC
  • »05.04.18 - 09:40
    Intuition
    - CISC
    Excellent! Looking forward to it. :)
  • »05.04.18 - 11:04
