Make: implicit variable CC unknown
    Posts: 650 from 2004/4/15
    Hello,
    when using make, there do exist implicit variables like CXX and CC.
    While CXX points to g++, which is absolutely correct, CC points to cc, wich is unknown in current SDK.
    How can I fix the path to the gcc compiler (just writing gcc in Makefile is to simple)?
  • »14.10.16 - 13:48
    Tom01
    Posts: 187 from 2009/9/20
    CC = gcc
  • »14.10.16 - 16:49
    Posts: 845 from 2007/10/23
    make CC=gcc
    is just a workaround, we should have another symbolic link.
  • »15.10.16 - 20:25
