POSIX compatibility
    Posts: 845 from 2007/10/23
    Hi!
    If you try to compile
    #include <sys/socket.h>
    you also have to include
    #include <sys/types.h>
    why?
  • »29.06.16 - 04:20
    Posts: 3332 from 2003/3/5
    Likely due to an error in includes. I'm assuming you are compiling *without* -noixemul?
  • »29.06.16 - 10:25
    Ok, here comes a patch
    --- include/sys/socket.h.bak	2016-06-05 23:04:57 +0100
    +++ include/sys/socket.h 2016-06-29 22:20:51 +0100
    @@ -38,6 +38,10 @@
    #ifndef _SYS_SOCKET_H_
    #define _SYS_SOCKET_H_
    +#ifndef _SYS_TYPES_H_
    +#include <sys/types.h>
    +#endif
    * Definitions related to sockets: types, address families, options.
    Next SDK:
    Please add the missing hpdf files.
  • »29.06.16 - 19:48
    No idea what those are, sorry. If something is missing that's up to the maintainer of a given module to add those to the SDK build.
  • »30.06.16 - 10:45
    deka
    Posts: 136 from 2013/2/12
    Is it possible to extend the SDK with man pages of the existing things? (Commands from Linux, developer stuff, ...)
  • »30.06.16 - 10:49
    Man pages for commands are part of the SDK. Did you check? Which one do you have in mind that seems missing?
  • »30.06.16 - 11:14
    deka
    All of them. Man command exists, but the pages for them aren't.
    memcpy, printf(3), the string handling commands, etc.
  • »30.06.16 - 12:32
    Those are in the Libnix.guide in the SDK documentation.
  • »30.06.16 - 12:58
    Okay, it was Itix' job. However you can find it in Aminet.
    BTW LibNIX.guide is not complete anymore
    LibNIX.guide 373 ----rw-d 05-Jun-16 22:09:22
    LibNIX.guide 834583 ----rw-d 22-Jan-16 08:47:57
    [ Editiert durch polluks 30.06.2016 - 21:39 ]
  • »30.06.16 - 15:27
    BTW LibNIX.guide is 373 bytes...
    It would seem that a wrong file made it into the build, damn :(
    [ Edited by jacadcaps 30.06.2016 - 15:43 ]
  • »30.06.16 - 15:36
    "Compiled by a robot slave of the MorphOS Team"? Seems to be a slave rebellion ;-)
  • »30.06.16 - 16:38
    Posts: 1092 from 2004/9/23
    Not again. We had issues with the apes already last year. Replaced them with robot slaves.
  • »30.06.16 - 17:00
    Posts: 1521 from 2003/2/24
    I try to remember HPDF files when I am back in Finland... :)
  • »01.07.16 - 10:07
    Yeah, don´t let your pretty wife wait too long ;-)
  • »01.07.16 - 21:15
    Posts: 650 from 2004/4/15
    BTW
    there also a little mistake in glut.h:
    it should be glutCreateWindow( const char* title );
    not glutCreateWindow( char* title );
    There is missing the "const".
  • »06.07.16 - 03:02
    eliot schrieb:
    BTW
    This is not the only issue especially with C++
    --- tgl/glu.h.bak       2016-01-22 09:43:05 +0100
    +++ tgl/glu.h 2016-03-06 17:29:37 +0100
    @@ -181,7 +181,7 @@
    #define gluOrtho2D(left, right, bottom, top) glOrtho(left, right,
    bottom, top, -1.0, 1.0)
    /* dummy added by Yomgui */
    -#define gluErrorString(x) "<gluErrorString() not implemented>"
    +#define gluErrorString(x) (GLubyte *)"<gluErrorString() not implemented>"
    #endif /* _NO_PPCINLINE */
    --- ppcinline/tinygl.h.bak 2015-06-19 13:50:17 +0000
    +++ ppcinline/tinygl.h 2015-08-30 15:58:22 +0000
    @@ -162,7 +162,7 @@
    (((void (*)(GLContext *, GLenum , const GLdouble *))*(void**)((long)(TINYGL_BASE_NAME) - 1162))(__p0, __p1, __p2))
    #define GLDrawElements(__p0, __p1, __p2, __p3, __p4)
    - (((void (*)(GLContext *, GLenum , GLsizei , GLenum , GLvoid *))*(void**)((long)(TINYGL_BASE_NAME) - 562))(__p0, __p1, __p2, __p3, __p4))
    + (((void (*)(GLContext *, GLenum , GLsizei , GLenum , const GLvoid *))*(void**)((long)(TINYGL_BASE_NAME) - 562))(__p0, __p1, __p2, __p3, __p4))
    #define GLTranslatef(__p0, __p1, __p2, __p3)
    (((void (*)(GLContext *, GLfloat , GLfloat , GLfloat ))*(void**)((long)(TINYGL_BASE_NAME) - 232))(__p0, __p1, __p2, __p3))
    @@ -321,7 +321,7 @@
    (((void (*)(GLContext *, GLenum , const GLfloat *))*(void**)((long)(TINYGL_BASE_NAME) - 1294))(__p0, __p1, __p2))
    #define GLCallLists(__p0, __p1, __p2, __p3)
    - (((void (*)(GLContext *, GLsizei , GLenum , GLvoid *))*(void**)((long)(TINYGL_BASE_NAME) - 892))(__p0, __p1, __p2, __p3))
    + (((void (*)(GLContext *, GLsizei , GLenum , const GLvoid *))*(void**)((long)(TINYGL_BASE_NAME) - 892))(__p0, __p1, __p2, __p3))
    #define GLLightf(__p0, __p1, __p2, __p3)
    (((void (*)(GLContext *, int , int , float ))*(void**)((long)(TINYGL_BASE_NAME) - 454))(__p0, __p1, __p2, __p3))
    @@ -729,7 +729,7 @@
    (((void (*)(GLContext *, GLint , GLint ))*(void**)((long)(TINYGL_BASE_NAME) - 550))(__p0, __p1, __p2))
    #define GLGetString(__p0, __p1)
    - (((GLbyte *(*)(GLContext *, GLenum ))*(void**)((long)(TINYGL_BASE_NAME) - 862))(__p0, __p1))
    + (((const GLubyte *(*)(GLContext *, GLenum ))*(void**)((long)(TINYGL_BASE_NAME) - 862))(__p0, __p1))
    #define GLUTMainLoop(__p0)
    (((void (*)(GLContext *))*(void**)((long)(TINYGL_BASE_NAME) - 718))(__p0))
    --- ./tgl/gl.h.bak 2015-06-19 13:50:18 +0000
    +++ ./tgl/gl.h 2015-07-02 12:16:46 +0000
    @@ -1176,7 +1176,7 @@
    void glFrontFace(int mode);
    -GLbyte *glGetString(GLenum tag);
    +const GLubyte *glGetString(GLenum tag);
    /* opengl 1.2 arrays */
    void glEnableClientState(GLenum array);
    @@ -1498,7 +1498,7 @@
    void GLFrontFace(GLContext *context, int mode);
    -GLbyte *GLGetString(GLContext *context, GLenum tag);
    +const GLubyte *GLGetString(GLContext *context, GLenum tag);
    [ Editiert durch polluks 07.07.2016 - 15:05 ]
  • »06.07.16 - 17:44
    Jupp3
    Posts: 1193 from 2003/2/24
    It's not really C++ related, it happens on C too with sane compiler arguments & const pointers.
  • »11.07.16 - 14:10
